Visual LISP, AutoLISP and General Customization
Link Attribute Paper to Model
4 REPLIES 4
Ktelang
452 Views, 4 Replies
Is there a way by which I can link  a paper space block attribute to model space block attribute
In other words
Paper space as a block Title and attribute "QTY"
Model space has a block X and attribute "QTY_MODEL"
Is it possible to edit "QTY" and as a result get automatic update on "QTY_MODEL"
I am not familiar with diesel/macros yet in Acad.
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
4 REPLIES 4
Rtogores
in reply to: Ktelang
This would require programming an object reactor. This is something that demands experience in Visual LISP...
Ktelang
in reply to: Rtogores
Thanks, I will look into that..
If you have anything handy and would you like to share it ?
Thanks in advance
stevor
You, or someone, could make a lisp routine to perform the edit of the first, by your input, and then update the second.
S
pbejse
In other words
Perhaps this will work for you:
Link between Text, Mtext and Attribute with Field
HTH
”Boost
