Line with block break - need loop
Message 1 of 1
Hi guys,
The function below make two break 2 points in line (for each interference with line-block)
Auxiliar functions - credits to Juerg Menzi (thank you)
http://www.menziengineering.ch
The routine works ok with 1 line, but I need 2 loops, for each line containing blocks.
To make a test, draw a circle, convert it to block, insert some copies in line, and execute MIB.
See... Break all interferences line-block.
I need to add loop to works with multiple lines containing blocks (along it)
Thanks in advance,
Rogerio
The code (start command: MIB)
(defun c:mib (/ VxGetInters VxGetBlockInters w1 w2 ss_lin 1ent lst lin ss_blk 2ent int_lst p1 p2 )
;-----------------------Auxiliar functions - begin
;VxGetBlockInters and VxGetBlockInters functions
;Credits to
;Juerg Menzi
;MENZI ENGINEERING GmbH, Switzerland
;http://www.menziengineering.ch
;Returns all intersection points between a block and an object
; -- Function VxGetBlockInters
; Returns all intersection points between a Block and an object.
; Copyright:
; ©2001-2002 MENZI ENGINEERING GmbH, Switzerland
; Arguments [Type]:
; Blk = Block object [VLA-OBJECT]
; Obj = Object [VLA-OBJECT]
; Mde = Intersection mode [INT]
; Constants:
; - acExtendNone Does not extend either object.
; - acExtendThisEntity Extends the Fst object.
; - acExtendOtherEntity Extends the Nxt object.
; - acExtendBoth Extends both objects.
; Return [Type]:
; > list of points '((1.0 1.0 0.0)...
    ; > Nil if no intersection found
    ; Notes:
    ; - Because of a (reported) bug in A2k4/A2k5/A2k6, the used explode method
    ; will fail on NUS blocks. No limitations in A2k, A2ki and A2k2
    (defun VxGetBlockInters (Blk Obj Mde / ObjNme PntLst TmpVal)
    (foreach memb (vlax-invoke Blk 'Explode)
    (setq ObjNme (vla-get-ObjectName memb))
    (cond
    ((or
    (not (vlax-method-applicable-p memb 'IntersectWith))
    (and
    (eq ObjNme "AcDbHatch")
    (eq (strcase (vla-get-PatternName memb)) "SOLID")
    (eq ObjNme "AcDb3dSolid")
    ((eq ObjNme "AcDbBlockReference")
    (if (setq TmpVal (VxGetBlockInters memb Obj Mde))
    (setq PntLst (append PntLst TmpVal))
    (T
    (if (setq TmpVal (VxGetInters memb Obj Mde))
    (vla-Delete memb)
    PntLst
    ;Returns all intersection points between two objects
    ; -- Function VxGetInters
    ; Returns all intersection points between two objects.
    ; Copyright:
    ; ©2000 MENZI ENGINEERING GmbH, Switzerland
    ; Arguments [Type]:
    ; Fst = First object [VLA-OBJECT]
    ; Nxt = Second object [VLA-OBJECT]
    ; Constants:
    ; Return [Type]:
    ; > List of points '((1.0 1.0 0.0)...
      ; Notes:
      ; - None
      (defun VxGetInters (Fst Nxt Mde / IntLst PntLst)
      (setq IntLst (vlax-invoke Fst 'IntersectWith Nxt Mde))
      (cond
      (IntLst
      (repeat (/ (length IntLst) 3)
      (setq PntLst (cons
      (list
      (car IntLst)
      (cadr IntLst)
      (caddr IntLst)
      PntLst
      IntLst (cdddr IntLst)
      (reverse PntLst)
      (T nil)
      ;-----------------------Auxiliar functions - End
      ;-----------------------Main function
      (vl-load-com)
      (setq n 0)
      (setq q 0)
      (setq ss_lin (ssget (list (cons 0 "*LINE"))))
      (if ss_lin
      (setq lin_len (sslength ss_lin))
      (setq 1ent (cdr (assoc -1 (entget (ssname ss_lin n)))))
      (setq lin (vlax-ename->vla-object 1ent))
      (setq ptlst (acet-geom-object-point-list 1ent 10));;need Express Tools instaled
      (setq ss_blk (ssget "f" ptlst (list (cons 0 "INSERT"))))
      (if ss_blk
      (setq blk_len (sslength ss_blk))
      (repeat blk_len
      (setq 2ent (cdr (assoc -1 (entget (ssname ss_blk q)))))
      (setq blk (vlax-ename->vla-object 2ent))
      (setq int_lst (vxgetblockinters blk lin 3))
      (setq p1 (car int_lst))
      (setq p2 (car (cdr int_lst)))
      (command "draworder" ss_lin "" "f")
      (command "break" p1 p2)
      (setq n (1+ n))
      (setq q (1+ q))
      (princ)
Replies (0)
