Visual LISP, AutoLISP and General Customization
Line from origin to object centers
12 REPLIES 12
Message 1 of 13
1210 Views, 12 Replies
Does anyone know of a LISP routine which will draw lines from the center/insertion point of multiple objects to 0,0,0 ?
Tags (3)
12 REPLIES 12
Message 2 of 13
pbejse
May i ask as to whats the purpose of this exercise? just curious is all 🙂
Message 3 of 13
in reply to: pbejse
I have a number of objects surrounding a sphere (thousands) which I would like to create lines from to the center of the sphere (co-ords 0,0,0) and then sweep the lines to create cylinders which I will boolean from the sphere.
Hope that makes sense. Any suggestions ?
Message 4 of 13
hmsilva
Objects are circles?
Henrique
Message 5 of 13
smaher12
in reply to: hmsilva
Here is my quick and dirty version of it.
(defun c:test (/ esel cp)
  (setq esel (entsel "\nSelect circle: ")
           cp (cdr (assoc 10 (entget (car esel))))
  (command "line" cp "0,0,0" "")
(princ)
Message 6 of 13
Kent1Cooper
Based on these assumptions:
1.  The objects could be of multiple types but all with insertion or insertion-like points [below assumes Circles, Points, and Blocks, but you could include Text/Mtext or some other things, and/or remove one or more types];
2.  They might be in various orientations/coordinate systems [since they surround a sphere];
3.  You can select them collectively somehow [via window(s) or something], and want to do that rather than pick one at a time;
4.  You want the Lines on the current Layer;
then the following seems to do the Lines portion of what I think you're asking, in limited testing:
(setq ss (ssget '((0 . "CIRCLE,POINT,INSERT"))))
(repeat (sslength ss)
  (setq ent (ssname ss 0))
  (entmake
    (list
      '(0 . "LINE")
      (cons 10 (trans (cdr (assoc 10 (entget ent))) ent 0))
        ;;; (trans) needed for Circles/Blocks when not in WCS
      '(11 0.0 0.0 0.0)
    ); list
  ); entmake
  (ssdel ent ss)
); repeat
Kent Cooper, AIA
Message 7 of 13
in reply to: Kent1Cooper
Kent you are the man ! Perfect.
One last question. Would it be possible for the lines to go to 0,0 but stay relative to their z co-ordinates ?
I may need to keep the booleans horizontal for a cleaner print (I am 3D printing this model) as the resolution in the Z is far higher than x,y.
Many thanks for your help 🙂
Message 8 of 13
Kent1Cooper
@Anonymous wrote:
.... Would it be possible for the lines to go to 0,0 but stay relative to their z co-ordinates ?
If I understand what you're asking correctly [run Lines from the object point to 0,0 in XY but with both Line ends at the Z coordinate of the object point, in the WCS], this does that:
  (setq
    ent (ssname ss 0)
    dxf10 (cons 10 (trans (cdr (assoc 10 (entget ent))) ent 0)); object point, in WCS
  ); setq
  (entmake
    (list
      '(0 . "LINE")
      dxf10
      (list 11 0.0 0.0 (cadddr dxf10)); use Z coordinate of object point
    ); list
  ); entmake
  (ssdel ent ss)
); repeat
Kent Cooper, AIA
Message 9 of 13
stevor
Try a mod of Kent's, and, note that circles with a x,y of 0,0 make the '0 length' LINEs:
 (defun KC_liner ( / ss rq p00 cp ncp )
  (setq p00 '(11 0.0 0.0 0.0)   rq 0
        ss (ssget "x" '((0 . "CIRCLE,POINT,INSERT")))
  ' remove the "X"  to manually select the circle entities
   (setq ent (ssname ss 0)  rq (1+ rq)
         cp (trans (cdr (assoc 10 (entget ent))) ent 0)
         ncp (list (car cp) (cadr cp) 0.0) )
     (entmake (list '(0 . "LINE") (cons 10 ncp) p00 ) ); entmake
     (ssdel ent ss)
     ;;(p_"rq")(W_"  1")
  ); repeat
 rq )
S
Message 10 of 13
Kent once again thankyou, this works perfectly on the circles I have tested it on.
However my circles have to be converted into 3D polylines. The lisp does not seem to work on them !
I assumed they would have an inserition point or centre and it would work the same way.
Any suggestions ?
Message 11 of 13
Kent1Cooper
Any suggestions ?
No, they don't have a defined center or insertion point, just a string of vertices, and AutoCAD doesn't have any way to know directly whether they all fall on a common circular path.  But if they're geometrically regular, a center can be calculated.  This:
http://cadtips.cadalyst.com/2d-editing/convert-regular-polygons-circles
contains a method to do that.  Appropriate parts could be transferred, but it would make the code a lot longer.
On the other hand, if the conversion to 3DPolylines is done by something that always does it in the same way, e.g. it always makes a regular polygon with the same number of vertices [or even just always an even number of vertices] in each conversion, then we can assume some of what that routine tests for, and a much simpler way could be devised to calculate their centers.  Are they regular in some predictable way?
Kent Cooper, AIA
Message 12 of 13
They dont seem to have any common propoerties. They start as circles then I import them into 3ds max and use bend and spherify modifers to turn the 2d layout into a spherical arrangement, then back into CAD where they become 3D polylines.
I guess I need to find an object which will retain a centre point or insertion point whne transfered between the two program. perhapes a point/node. Il see what I can find. Any suggestions welcome. Thanks for your help so far.
Message 13 of 13
I found a MAXscript which placed point at the center of each spline (3d polylines in CAD) and bingo your lisp worked perfectly. Many thanks ! 🙂
”Boost
