I used to use a program called Strucad and if I had say 5 layers turned of from my batch of say 20 layers, there was a command that allowed you turn on a certain layer by choosing one of the 5 off layers. Strucad would present a window, only showing the layers that I had turned of
Is there something around to allow me to do this in Autocad 3013
@Kent1Cooper wrote:
One possible drawback, however, is that there actually needs to be something drawn on the Layer(s) you want thawed/on. You can't use it to thaw and turn on a Layer that has nothing drawn for you to pick on.
Having not viewed the code you posted, an easy enhancement to mitigate this lone drawback, is to allow the user to Enter either a non-selection, or "... [List empty layers]<List empty layers>: " option, which would in turn generate a DCL/DOSLib dialog accordingly.
Given your talent, something such as this is nothing but a matter of your time.
Just a thought.
"How we think determines what we do, and what we do determines what we get."
Hi, phanaem
Excellent code! (code is post#7 Author: Stefan M.)
I've noticed that the code just works for layers OFF. How can I change to work for freeze layers too?
I'd like to use in both situation.
Regards
