Visual LISP, AutoLISP and General Customization
Layers ON/OFF automatically
5 REPLIES 5
aqdam1978
604 Views, 5 Replies
I know that for layers ON/OFF in current open dwg file, I should use:
[I just want to On/Off for my "STAMP" layer]
(COMMAND "LAYER" "ON" "STAMP" "")
(COMMAND "LAYER" "OFF" "STAMP" "")
but I have more than 150 dwg file and I should open all of dwgs one by one and setting ON/OFF for STAMP layer for every drawing and it takes so much time! 😞
is there any solution for my question?
I just want to select files and LISP program set the STAMP layer to ON or OFF value.
can anybody help me?
Thanks.
5 REPLIES 5
pbejse
in reply to: aqdam1978
Thanks.
On or Off? which one is it?  On if its off? and vice versa?
aqdam1978
in reply to: pbejse
Hi pbejse,
the first step is OFF.
In fact I need two lisp program, one for OFF and one for ON!
But there are 99% similiar!
if I have OFF lisp, so I will have ON lisp too!
pbejse
@aqdam1978 wrote:
Hi pbejse,
We can use ODBX. only "drawback" is you loose the thumbnail preview. but its not a big deal. when you open the file and save you will get it back
These are the supporting sub funcitons
(defun Get_Folder (/  sObj cFold fobj oval sto fto)
  	(setq sObj (vla-getInterfaceObject
                	(vlax-get-acad-object)"Shell.Application")
        		cFold(vlax-invoke-method sObj 'BrowseForFolder 0 "Select Folder for Layer Files" 512))
			(vlax-release-object sObj)
			(setq fObj(vlax-get-property cFold 'Self)
            			oVal (vlax-get-property fObj 'Path))
			(foreach sto (vl-directory-files oval "*.dwg")
			  	(setq fto (cons (strcat oval "\\" sto)  fto))
		(vlax-release-object cFold)
      		(vlax-release-object fObj)
	 	fto
(defun _OnOffLayer (ln doc m)
      (if (not (vl-catch-all-error-p (setq la (vl-catch-all-apply 'vla-item
									(list (vla-get-layers doc) ln)))))
          	(vlax-put la 'Layeron m))
(defun _Odbx  (fileNames ln m)
      (cond ((and
                   (setq myDoc
                              (vla-GetInterfaceObject
                                    (vlax-Get-Acad-Object)
                                    (strcat
                                          "ObjectDBX.AxDbDocument."
                                          (substr (getvar 'AcadVer)
                                                  1
                                                  2))))
                   (foreach
                          File  Filenames
                         (if (not (vl-catch-all-apply
                                        'vla-Open
                                        (list myDoc file)))
                               (progn
                                     (_OnOffLayer
                                           ln
                                           myDoc
                                           m)
                                     (vla-saveas myDoc File)
                               T
                   (vl-catch-all-apply
                         'vlax-Release-Object
                         (list myDoc))
(vl-load-com)
 and this are the commands
(defun c:ons ( / Files)
	(if (setq files (Get_Folder))
      (_odbx files "STAMP" -1))
      (princ)
(defun c:ofs ( / Files)
      (_odbx files "STAMP" 0))
      (princ)
You can change the layer name to your liking
HTH
aqdam1978
in reply to: pbejse
Hi Pbejse,
As usual your program is GREAT!
Excellecnt!
Thank you so much.
pbejse
@aqdam1978 wrote:
Thank you so much.
You are welcome. 🙂
Glad i could help
”Boost
