Is somebody could make a code to apply a layer filter with one command withou going into the layer dialog box.
Go see the attached file.
Marcel
An easy option is to use the hidden FILTER option of the -LAYER command:
Command: -layer Current layer: "0" Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: Filter Enter a layer filter option [New/Set/Rename/Edit/Delete/eXit]:
