- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Laydel by lisp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi guys,
Based on the tip from *Paul Turvill : http://forums.autodesk.com/t5/Visual-LISP-AutoLISP
(defun c
eleteLayerTavail ()
(setq ss (ssget "x" '((8 . "Tx-Travail"))))
(command "_.erase" ss "")
(princ)
The routine works great but I notice that if I don’t have this layer, it will return an error. Could someone update this to just ignore if the drawing don’t have the layer Tx-Travail?
I need this because I will use this routine together with another routines and in some cases I will not have the layer specified.
Thanks for help!
Re: Laydel by lisp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
msarqui wrote:Hi guys,
-and-General/Delete-a-Layer-with-Laydel/td-p/21742 ... I made this routine:
(defun c
eleteLayerTavail ()
(princ)
Thanks for help!
(defun c:DeleteLayerTavail ()
(if (setq ss (ssget "x" '((8 . "Tx-Travail"))))
(command "_.erase" ss ""))
(princ)
or
(defun DeleteLayer (lay)
(cond ((and
(tblsearch "LAYER" lay)
(setq ss (ssget "x" (list (cons 8 lay))))
(repeat (setq i (sslength ss))
(entdel (ssname ss (setq i (1- i)))))
(princ)
(deleteLayer "layername")
Re: Laydel by lisp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Why it does not work if the layer is not in the current space.
Can be set to erase the layer in both spaces like the LAYDEL command?
Thanks!
Re: Laydel by lisp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
msarqui wrote:Why it does not work if the layer is not in the current space.
Thanks!
Try this instead
(vlax-for layout (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for i (vla-get-block layout)
(if (eq (vla-get-layer i) lay)
(vla-delete i)))
Re: Laydel by lisp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello pbejse
I start to understand and do some basic routines but my knowledge is still very small. So when I see these VLA things I do not understand at all. This is like chinese language to me ![]()
So, I tried this :
(defun c
eleteLayer (lay)
(vlax-for Tx-Travail (vla-get-block layout)
(if (eq (vla-get-layer Tx-Travail) lay)
(vla-delete Tx-Travail)))
And I got this error: Command: too few arguments
Thanks for your time.
Re: Laydel by lisp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
msarqui wrote:Hello pbejse
So, I tried this :
msarqui
To use snippet i posted
(DeleteLayer "Tx-Travail")
It is a generic routine that accepts a layer name as argument
If you need to a command to work for a specific layer
(defun c
eleteLayerTavail ()(DeleteLayer "Tx-Travail"))
Also take note that the layer name is case sensitive: in that case we can modify the routine to
(if (eq (strcase (vla-get-layer i))
(strcase lay))
(vla-delete i)))
Better yet , to use the routine for one or more layer names
(defun DeleteLayer (lst)
(if (member (strcase (vla-get-layer i))
(mapcar 'strcase lst))
(vla-delete i)))
(DeleteLayer '("Tx-Travail" "otherLayer" "AnotherLayer"))
Now, going back to your original post
(defun c
eleteLayerTavail ()(DeleteLayer '("Tx-Travail")))
HTH
Re: Laydel by lisp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This two works great and realy fast:
(defun c:dlt1 ()(DeleteLayer "Tx-Travail"))
(strcase lay))
(vla-delete i)))
(defun c:dlt2 ()(DeleteLayer "Tx-Travail"))
(vla-delete i)))
But this one with the list returns "nil" and do nothing:
(defun c:dlt3 ()(DeleteLayer '("Tx-Travail" "Tx-1" "Tx-2" "Tx-3")))
(vla-delete i)))
Re: Laydel by lisp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
(vla-delete i)))
Works on my end , its either there are no objects on the listed layer or the layer doesnt exist. or worse the entities are on a locked layer.
What you can do is add a sub to unlock all layers then invoke the command
(defun DeleteLayer (lst / n)
(setq n 0)
(if (member (strcase (vla-get-layer i)) (mapcar 'strcase lst))
(progn (vla-delete i)
(setq n (1+ n)))
(princ (strcat "\n" (itoa n) " Objects deleted"))
(princ)
)HTH
Re: Laydel by lisp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I got this error: Command: Automation Error. On locked layer
So I made this:
(command "-layer" "s" "0" "u" "*" "on" "*" "t" "*" "")
(setq n 0)
(setq n (1+ n)))
(princ)
And now it works. ![]()
Re: Laydel by lisp
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
msarqui wrote:I got this error: Command: Automation Error. On locked layer
So I made this:
.....And now it works.
Good for you msarqui ![]()
"i'll leave the "unlocking" to the user"
BTW: (command "_layerp");;<-----
