• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Member
    Last Command?
    79 Views, 9 Replies
    06-04-2007 09:56 PM
    How can I get the last command that I used?
    Im trying to use that last command in my lisp routine.
    help please.
    Troadio
    ACAD2006
    Please use plain text.
    *Adesu
    Re: Last Command?
    06-05-2007 01:59 AM in reply to: Troadio
    Hi Troadio,
    How about this code.
    [code]
    (defun c:test (/ p1 p2)
    (setq p1 '(0 0 0))
    (setq p2 '(10 5 0))
    (command "_line" p1 p2 "")
    (command "_line")
    (princ)
    [/code]
    wrote in message news:5616163@discussion.autodesk.com...
    help please.
    Troadio
    ACAD2006
    *Ken Krupa
    Re: Last Command?
    06-05-2007 08:59 AM in reply to: Troadio
    Well, this would do what you are asking for:
    (defun xxx()(command "")(princ))
    So if the last command was LINE, running (xxx) would start the line command.
    I don't see why you would want to do that though. What are your trying to
    accomplish?
    Also note that the lisp cannot be a command function (c:xxx), because
    running XXX as a command would try to repeat the XXX command.
    Ken Krupa
    help please.
    Troadio
    ACAD2006
    Distinguished Contributor
    Re: Last Command?
    06-05-2007 01:02 PM in reply to: Troadio
    You might need to be more specific about how you want to use the last command. generally you cant use the command history. But it depends on what you are trying to do exactly
    http://discussion.autodesk.com/thread.jspa?messageID=5499473
    http://discussion.autodesk.com/thread.jspa?messageID=4820677
    http://discussion.autodesk.com/thread.jspa?messageID=4211127
    Regards
    Phill
    Member
    Re: Last Command?
    06-05-2007 06:56 PM in reply to: Troadio
    Hi Ken,
    nice tip, Ive been using (defun c:xxx()). It is self repeating and you eplain why. My question now is how could I use this in the command line w/o having to enter (xxx). Just xxx.
    Troadio
    *Ken Krupa
    Re: Last Command?
    06-06-2007 07:02 AM in reply to: Troadio
    You can't do that, you need to do (xxx). I still can't imagine what you're
    trying to accomplish though. If you explain, maybe I (or someone else) could
    suggest something better.
    wrote in message news:5617454@discussion.autodesk.com...
    Hi Ken,
    Troadio
    *Bill Gilliss
    Re: Last Command?
    06-06-2007 11:04 AM in reply to: Troadio
    Hard to tell, but it sounds like he wants to repeat the previous
    command, maybe inside of MULTIPLE -- he liked it so much he wants to do
    it many times, but doesn't want to retype it.
    Although I see no sign of a system variable like ACADLASTCOMMAND, it has
    to be stored somewhere to be able to be resurrected with (command ""),
    so perhaps there is a registry entry somewhere. But.. would the command
    to retrieve it take its place before it could be read? Deep metaphysics
    here...
    -Bill
    > Regards
    > Phill
    Re: Last Command?
    06-06-2007 11:12 AM in reply to: Troadio
    If we solve this one we should start looking at the old 'chicken or the egg' problem!!
    :smileyhappy:
    P
    *Ken Krupa
    Re: Last Command?
    06-06-2007 12:58 PM in reply to: Troadio
    I don't think it could be stored in the reg, since each drawing remembers
    what its last command was. It's probably stored somewhere that us mere
    mortals can't get at.
    Ken Krupa
    "Bill Gilliss" wrote in message
    news:5618428@discussion.autodesk.com...
    here...
    -Bill
    > Regards
    > Phill
    *Gekko
    Re: Last Command?
    06-07-2007 04:51 AM in reply to: Troadio
    wrote in message news:5618437@discussion.autodesk.com...
    problem!!
    :smileyhappy:
    NO, dont do that, not yet anyways;; we first have to consult Mataeux as
    per his reply to a post 6/7/07. ";error: too few arguements".....
    he will love this!
