Hi Everyone,
I was wondering if anyone is able to help me, I was looking for a lisp routine which will add the bearing and distance to lines, polylines and arcs when I click on them or select them individually. It would be great to have the one routine which does lines and arcs which would save me loading 2 seperate lisps. The resulting text would read like:-
Lines or polylines
42°25′35" (degrees minutes seconds, no spaces) bearing on seperate line
354.545 distance on seperate line, 3 decimal places
If possible also to round the bearing to the nearest 5" and the distace to the nearest 5 millimetre as shown above.
Arcs
56°42′15" bearing of chord to nearest 5"
43.625 distance of chord to nearest 5 millimetre and 3 decimal places
A44.835 arc distance to nearest 5 millimetre and 3 decimal places
R400.005 arc radius to nearest 5 millimetre and 3 decimal places
Bearing and the chord of the arc on one line, space in between
Arc and Radius on another line, space in between
If not possible have each on a seperate line.
Very much appreciated if anyone can help.
Cadmonkey
Thanx for your time 3wood, although I am after a lisp routine which will place the text adjacent to the line, polyline or arc and ideally on the same rotation as the line. Can anyone help or point me in the right direction.
Cadmonkey
