Hi
New to the forum.
Could anyone one help with a LISP that adds a text to identify a radius/straight of a line (see attached jpg).
Could it:
Inserts perpendicular to line
Radius to 1 decimal place
Finishes with 'mR'
Straight line displays as 'STR'
I have tried doing this using dynamic blocks - doesnt work, and i have no programming knowledge so i'd be lost on actually writing LISP routines.
Thanks in advance
PS We use this a lot and would save immense amount of time
@jhockley wrote:
Could anyone one help with a LISP that adds a text to identify a radius/straight of a line ...:
Finishes with 'mR'
Welcome to the Forums!
If a dimension's extension line would serve in place of the perpendicular line, perhaps with the DIMEXO System Variable set to 0 so that it touches the Polyline vertex, then a simple modification of this recent routine could do that. It would just require applying "STR" as override text on all line-segment dimensions, using the radius rather than segment length as override and putting the right mode and precision and suffix on all arc-segment dimensions, and suppressing all dimension lines. Using a Dimension Style that puts the text above the dimension line [the routine is built assuming text centered on the dimension line as in our standard style] would simplify the positioning -- right on the segment. Does that sound like it would work for you? If you really need a perpendicular line that looks like your image, that wouldn't be difficult to work into it, though the question arises whether all line-to-arc-segment intersections will always be tangents.
@Kent1Cooper wrote:
....If a dimension's extension line would serve in place of the perpendicular line, ... then a simple modification of this recent routine could do that. .... the question arises whether all line-to-arc-segment intersections will always be tangents.
Such as the attached [not quite as simple a modification as I expected, but not too bad]. And I didn't do the text-above-dimension line thing, because there was then no difference between the result when asking for the indicators inside vs. outside.
In limited testing, it also raises the question of the desired vertex marker at vertices between non-collinear line segments. The attached puts two extension lines, which of course don't coincide the way they do between tangent line and arc segments, or two tangent arc segments, or two collinear line segments. If you want only one marker, in that situation should it bisect the angle or something?
Search the file for four semicolons together ;;;; and consider the comments. There may be other adjustments you want to make, but give this a shot.
