• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Valued Contributor
    LISP to create a two line MLEADER
    141 Views, 2 Replies
    07-18-2012 08:36 AM
    I'm trying to write a lisp routine to create a two line MLEADER but i can only get one line of text. Creating the MLEADER manually from the command line i just have to hit enter after the first line of text to add a second line. How would i do this in a lisp routine?
    Larry
    Please use plain text.
    *Expert Elite*
    Hallex
    Re: LISP to create a two line MLEADER
    07-22-2012 02:42 PM in reply to: bdsmls
    Hi, Larry
    Try this routine, set your text before:
    (defun C:demo(/)
    (setq txt "Blah\\PBlah\\PBlah");<-- set mleader text here
    (princ "Type any character in the mtext window")
    (command "_mleader" "_O" "_C" "_M" "_A" "_Y" "" "_X"  "_L" "_C" pause pause pause)
    (setq ee (entget (setq en (entlast))))
    (setq ee (subst (cons 304 txt)(assoc 304 ee) ee))
      (entmod ee)
      (entupd en)
      (command "_mleaderedit" "_L" "" "_A" (getpoint ) "")
      (princ)
    ~'J'~
    _____________________________________
    C6309D9E0751D165D0934D0621DFF27919
    Valued Contributor
    07-23-2012 04:09 AM in reply to: Hallex
    thanks for the response J
    i just came up with a solution on friday thats works very nicely
    (SETQ TELE(STRCAT TPFIX (RTOS TLV 4 2)))
    (SETQ BELE(STRCAT BPFIX (RTOS BLV 4 2)))
    (SETQ DUCEL(STRCAT TELE (CHR 10) BELE))
    (COMMAND "MLEADER" BPT PAUSE DUCEL)
