Visual LISP, AutoLISP and General Customization
LISP request: create local layer filter
12 REPLIES 12
Message 1 of 13
barry2104
4090 Views, 12 Replies
Hello everyone!
I often work on drawings which have multiple xrefs, each having up to 100 Layers or more, so the layer manager can be a bit difficult to trawl through to find a local layer to select.
I know how to create a local layer filter using the code ~*|* from the new filter area in layer manager, but I wonder if anyone has/can quickly knock up a code to speed this process up.
Ideally all I want to have to type in is: LOCAL
and then the local layer filter would be created, with the filter name being Local-Layers (or similar).
any ideas/help muchly appreciated!!
Running AutoCAD Architecture 2020, in German
12 REPLIES 12
Message 2 of 13
Lee_Mac
in reply to: barry2104
Try this quick code:
(defun c:local ( / dc fn xd )
    (setq fn "Local-Layers") ;; Filter Name
    (if
        (and
            (setq xd
                (cdr
                    (assoc 360
                        (entget
                            (cdr
                                (assoc 330
                                    (entget
                                        (tblobjname "layer" "0")
            (or (setq dc (cdr (assoc -1 (dictsearch xd "ACAD_LAYERFILTERS"))))
                (setq dc
                    (dictadd xd "ACAD_LAYERFILTERS"
                        (entmakex
                                (000 . "DICTIONARY")
                                (100 . "AcDbDictionary")
                                (280 . 0)
                                (281 . 1)
            (null (dictsearch dc fn))
        (dictadd dc fn
            (entmakex
                (list
                   '(000 . "XRECORD")
                   '(100 . "AcDbXrecord")
                   '(280 . 1)
                    (cons 1 fn)
                   '(001 . "~*|*")
                   '(001 . "*")
                   '(001 . "*")
                   '(070 . 0)
                   '(001 . "*")
                   '(001 . "*")
                   '(-3
                            "ACAD"
                            (1000 . "( NAME== \"~*|*\" )")
    (princ)
Message 3 of 13
barry2104
in reply to: Lee_Mac
hmm doesn't seem to work/do anything when I type in LOCAL after loading her in... does it work for anyone else out there?
Message 4 of 13
alanjt_
FYI, you can also create layer filters from the -layer command.
eg.
Command: la
-LAYER
Current layer:  "0"
Enter an option
[?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Fre
eze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: filter
Current layer filter: "All"
Enter a layer filter option [New/Set/Rename/Edit/Delete/eXit]:
Message 5 of 13
Lee_Mac
Does it not create the layer filter as required?
Did you check the Layer Manager after using the program?
Message 6 of 13
barry2104
aha, got it now. I had the layermanager open to my left as I typed in the new command, but saw nothing new pop up into the filter list.
after posting my response, I realised that the layermanager needs to be CLOSED and then REOPENED for the changes to become apparent.
I'm assuming this closure and reopening cannot be avoid by tweaking the script further?
thanks a lot Lee Mac - you are a wealth of knowledge!
Message 7 of 13
barry2104
Message 8 of 13
Lee_Mac
Thank Barry Smiley Happy
Since I am adding the layer filter XRecord directly to the ACAD_LAYERFILTERS dictionary, it is likely that the Layer Manager would need to be reopened to read any new items from this dictionary.
In this case, it may be simpler to follow Alan's suggestion of automating the -LAYER command to create & set the layer filter current, rather than my rather more 'purist' route. Smiley Wink
Happy to help.
Message 9 of 13
alanjt_
*giggle*
Message 10 of 13
3wood
I have tried the code, it creates a new filter but the layer manager and layer toolbar don't work properly. The layer list doesn't update when you click any filter items including filters under xref. Smiley Sad
BTW, there are some rouintes in the forum which allow you setup some filter conditions in a txt file. When you open a drawing, the routine can read it and create filters for you.
Message 11 of 13
mpe
If I use the -layer command with the filter option to create a property filter, how should I define my filter definition?
For instance if I want all layers from which the name starts with X-.
Any tips are very welcome!
Marcel Pennings
Message 12 of 13
hmsilva
in reply to: mpe
try
(command "-layer" "_filter" "_N" "_P" "" "NAME==\"X-*\"" "MyTestFilter" "")
HTH
Henrique
Message 13 of 13
Hello there,
I'm trying to add your suggestions to a lisp routine i use to insert blocks.
but i cannot seem to get the layers to add to the group filter
The filters are all created fine, it just won't add the layers to the filter.
Any ideas?
I am using the following
(command "-layer" "_filter" "_N" "_G" "Formwork" "M_PANEL" "EcoAS" "")
(command "-layer" "_filter" "_S" "All" "" "")
or
(command "-layer" "Fil" "N" "G" masterGRPname eLay subGRPname "")
Lee
”Boost
