Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Puckett, Michael
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
10-20-1999 07:59 PM in reply to:
*Nagel, Eric
Good call Vladimir.
________________________________
puckettm@cadvision.com
> Not < a Member of the AutoDESK
Discussion Forum Moderator Program
Imagination makes all things possible.
Vladimir Nesterovsky wrote in message
news:380e51da.45281500@adesknews.autodesk.com...
Eric -- if your file is sometimes working, and
sometimes doesn't, if it works OK right after
you appload it, ---- it's obvious that you have
some other file defining another MAIN function,
which *does* have an mspace command in it.
You can try and put all your dependent functions
inside the main one, like
(defun c:LS2 (/ main layer)
(defun layer() ..... )
(defun main () ..... )
(setq dcl_id (load_dialog "ls2.dcl"))
(if (new_dialog "ls2" dcl_id)
(progn
(action_tile "accept" "(MAIN) (done_dialog)")
(action_tile "cancel" "(done_dialog)")
(start_dialog)
(unload_dialog dcl_id)
(LAYER)
(princ)
so that these functions are always defined properly
when your command is called.
See if this helps.
On Tue, 19 Oct 1999 14:26:34 -0700, Eric Nagel wrote:
>I forgot to mention that that I am loading this routine thru my
>'acadr14.lsp' file. When I appload the file, it works just fine...I'm
>stumped...
>Eric Nagel wrote:
>> Greetings All !
>> I am having an odd problem that I cannot seem to figure out. I am
>> hoping someone will be able to help me out with this...Notice that I do
>> not have an "mspace" command anywhere in my code. Any pointers would be
>> thanked...
>> Thanks,
>> Eric
>> Here is the error message that I am getting:
>> Command: ls2 error: incorrect request for command list data
>> (COMMAND ".mspace")
>> (MAIN)
Vlad http://vnestr.tripod.com/
(progn
(start_dialog)
(LAYER)
(princ)
See if this helps.
>stumped...
>Eric Nagel wrote:
>> Greetings All !
>> thanked...
>> Thanks,
>> Eric
>> (COMMAND ".mspace")
>> (MAIN)
*Herrin, Mark
Re: LISP QUESTION
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-18-2003 01:57 AM in reply to:
*Nagel, Eric
Ok on all of my drawings for this company we use drawing footers to
determine where the drawing is located, My question is, Is it possible to
write a lisp so that when you open a drawing or save a drawing in a new
place that it updates the footer text, If it could be done could someone
help get me pointed in the right direction. Thanks!
*Turvill, Paul
Re:
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
02-18-2003 01:59 AM in reply to:
*Nagel, Eric
Do you have Express Tools? Sounds like a job for RText.
___
"Mark Herrin" wrote in message
news:87BCE4AF8F84CB233B1F23E5FDAC51C6@in.WebX.maYI adrTaRb...
___
"Mark Herrin"
