I am wanting to make a LISP routine that will change the project properties of an AutoCAD Electrical project.
I am trying to change is the Library and icon menu paths in the project properties.
What I am thinking is there are two ways to go about this...
One, edit the properties in AutoCAD Electrical itself, as I do not know how to do this.
Or, edit the project properties file located in the root directory of the active project.
I'm thinking the latter may be the solution here, because the project properties file can be edited like a text file.
Either way, I am working on where to start. So if anyone has any input on the matter, the expertise is greatly appreciated!
--Thanks as always!
Did you ever solve this problem? I'm in a similar situation in needing a simple tool to change library paths for my users.
