Visual LISP, AutoLISP and General Customization
LISCP or SCRIPT for renaming ladders in AutoCAD Electrical
6 REPLIES 6
842 Views, 6 Replies
I am looking for either a LISP routine or SCRIPT to eventually do all of the following:
1.)  Insert Drawings into a project from a server directory
2.)  Rename ladders on each drawing
3.)  Update Symbol Tags, WireNumbers, and Cross References
Any ideas from the experts out there?  I am new to LISP but have begun reading here: http://www.afralisp.net/visual-lisp/
Thanks!
6 REPLIES 6
I have already completed the LISP that finds the first components of the ladders and then updates the values accordingly in FIRSTRUNG but then when i try to call the object method Update() with:
(vla-update AXName) ; where AXName is the Active X object of the first element in ladder
But the ladders don't update the rest of the rungs . . .
Any ideas??
It looks as though the rest are just text and don't mean anything and there isn't a method to invoke, I just have to go in and change all the text . . . crikee
hmsilva
Hello crosby.109 and welcome to the Autodesk Community!
I'm not a AutoCAD Electrical guy, and I don't think there are many out here, let's wait and see.
In the meantime, let's see if I can give you some help...
For the: Insert Drawings into a project from a server directory
you can try
(c:ace_add_dwg_to_project "//servername/dir/dwgname.dwg" (list "" "" (list "" "FirstlineDrawing description" "SecondlineDrawing description") nil))
where the paramlst are:
(nth 0 ) = "Sec" section code.
(nth 1 ) = "Subsec" code.
(nth 2 ) = "Drawing description" or list of three descriptions.
(nth 3 ) = 1 to suppress project file freshen after drawing is added to project.
HTH
Henrique
in reply to: hmsilva
Thanks!
I will mark you as the answer if you know how to rename the drawing after adding it in. . . or where there is any directory on a list of commands such as c:ace_add_dwg_to_project.  I feel like there is a lack of literature and makes it unnecessarily difficult to learn
I already finished the changing rungs and text automatically per drawing and was planning on creating a .scr file that ran project wide which ran my LISP first, then RETAG Components, then Wire Numbers refresh . . .
hmsilva
You're welcome, crosby.109
as I said earlier, I'm not a AutoCAD Electrical guy, therefore I have no way of testing with AutoCAD_E...
But this might help you!
HTH
Henrique
gcsjlewis
Here is what i use to do something very similar:
(setq project_wdp_location (ace_getactiveproject)); This will get the active drawing file location
(setq space_location (vl-string-position 32 (vl-filename-base project_wdp_location) 3)); this will grab only a part of the drawing name
You will have to customize this for yourself and your own standards
(setq new_file_titlepage (strcat (vl-filename-directory project_wdp_location) "\\" first_part "-01.dwg"));; This will create a new file in your "job folder"
(setq tite_page (vl-file-copy "Template extension goes here" new_file_titlepage));; This will copy your template into the drawing you created from the code above
(c:ace_add_dwg_to_project  new_file_titlepage  (list "" "" (list "TITLE PAGE" "DRAWING INDEX" "") nil)); this adds it to the active project and sets descriptions
Hope this helps
”Boost
