• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Active Contributor
    Keyboard shortcuts
    222 Views, 5 Replies
    06-03-2011 10:59 AM
    All,
    I have had keyboard shortcuts set for 2010 and earlier for osnap input such as SHIFT+S for insertion, SHIFT+E for endpoint, etc.  In 2011 I can use these once and then it just gives me the capital letter in the command line.  Any idears on what's gooing on?
    Eric
    Please use plain text.
    Active Contributor
    Re: Keyboard shortcuts
    06-03-2011 01:03 PM in reply to: esfransen
    I just discovered this:  When I am not in a command and I press SHIFT+A for nea snap I get nea returned at the command line but while in the comand, I get sometimes, the first nea but not the next.
    No comnad active gets this:
    Command: nea Unknown command "NEA".  Press F1 for help.
    Command: ins Unknown command "INS".  Press F1 for help.
    Command: endp Unknown command "ENDP".  Press F1 for help.
    Command: cen Unknown command "CEN".
    In a command I get this:
    Command: l LINE Specify first point:   Eendp (Pressing SHIFT+E for endp)
    Invalid point.
    Invalid point.
    Invalid point.
    *Pro
    M_Hensley
    06-06-2011 04:13 AM in reply to: esfransen
    Why don't you try switching from SHIFT + to CTRL + for shortcuts? They work better that way.
    Member
    06-06-2011 09:22 AM in reply to: esfransen
    SHIFT+E works fine with 2011 on my computer.  They need to remain set up as Temporary Override Keys.  SHIFT+E is the default for endpoint and SHIFT+C for center.  Object Snap Override : Insertion is listed, but you need to set the key combination to use it.  Try not to change key combinations already assigned to a function to keep standard one functional.  Just like ENDP, INT, INS, etc... Temporary Override Keys should only work when a command is expecting a point.
    AutoCAD Map & Civil 3D
    Active Contributor
    06-06-2011 09:52 AM in reply to: beaufordt
    So it sounds llike I need to remove the keyboard short cuts that I had in place prior to migration.  Are the Temporary override keys on automatically or is the a system variable that I need to set?
    Member
    06-06-2011 10:35 AM in reply to: esfransen
    Check out: http://forums.autodesk.com/t5/AutoCAD-2006/OSNAPOVERRIDE/td-p/1299607
    By default they should be on.  To use endpoint while in the line command press and hold SHIFT+E while snaping.  Kinda nice to be able to use the same keyboard shortcut for different things in different situations.  There's only so many key combinations available.
