qlset.lsp - example initialization of QLEADER settings
Frank Whaley, Autodesk
Two functions are included in this file:
(acet-ql-get)
Returns an association list containing the current QLEADER settings from the
Named Object Dictionary.
(acet-ql-get
Sets the specified values for QLEADER settings from the given association
list.
Returns an association list containing the new values.
These functions can be used to examine the current QLEADER settings, or to
initialize the setting before using the QLEADER command.
For example, to use splined leaders and framed text:
(acet-ql-set '((65 . 1)(72 . 1)))
Both functions use the following group codes to identify QLEADER settings:
3: user arrowhead block name (default="")
40: default text width (default=0.0)
60: annotation type (default=0)
0=MText
1=copy object
2=Tolerance
3=block
4=none
61: annotation reuse (default=0)
0=none
1=reuse next
62: left attachment point (default=1)
63: right attachment point (default=3)
0=Top of top line
1=Middle of top line
2=Middle of multiline text
3=Middle of bottom line
4=Bottom of bottom line
64: underline bottom line (default=0)
65: use splined leader line (default=0)
66: no limit on points (default=0)
67: maximum number of points (default=3)
68: prompt for MText width (word wrap) (default=1)
69: always left justify (default=0)
70: allowed angle, first segment (default=0)
71: allowed angle, second segment (default=0)
0=Any angle
1=Horizontal
2=90deg
3=45deg
4=30deg
5=15deg
72: frame text (default=0)
170: active tab (default=0)
0=Annotation
1=Leader Line & Arrow
2=Attachment
340: object ID for annotation reuse
{code}
(defun acet-ql-get (/ xr cod itm reply)
(if (setq xr (dictsearch (namedobjdict) "AcadDim"))
(progn
(foreach cod
'(3 40 60 61 62 63 64 65 66 67 68 69 70 71 72 170 340)
(if (setq itm (assoc cod xr))
(setq reply (append reply (list itm)))
reply
'((3 . "")
(40 . 0.0)
(60 . 0)
(61 . 1)
(62 . 1)
(63 . 3)
(64 . 0)
(65 . 0)
(66 . 0)
(67 . 3)
(68 . 1)
(69 . 0)
(70 . 0)
(71 . 0)
(72 . 0)
(170 . 0)
(defun acet-ql-set (arg / cur prm)
;; fetch current
(setq cur (acet-ql-get))
;; override per argument
(while arg
(setq prm (car arg)
arg (cdr arg)
cur (subst prm (assoc (car prm) cur) cur)
;; handle DIMLDRBLK
(if (= 3 (car prm))
(setvar "DIMLDRBLK" (cdr prm))
;; put back
(dictremove (namedobjdict) "AcadDim")
(setq
cur (append '((0 . "XRECORD") (100 . "AcDbXrecord") (90 . 990106))
cur
(dictadd (namedobjdict) "AcadDim" (entmakex cur))
(acet-ql-get)
;; load quietly
(princ)
{code}
(defun botsbuildbots() (botsbuildbots))
