Isn't there supposed to be an ENDBLK entity in a block definition?
mdhutchinson
Advisor Advisor
mdhutchinson
What is it about a block with attributes, some other entities and a wipeout object as the last entity that doesn't have an ENDBLK entity?
you are expected to make an ENDBLK when defining a block
but when you create a block reference - an INSERT - a SEQEND follows
attributes
same with POLYLINEs , a SEQEND follows the VERTEXs
wrote in message news:[email protected]...
mdhutchinson
yes I know this... but... no... i was seaching through a block definition (in the database, not a block reference) to check if the right attribute tags existed and didn't see the ENDBLK entity come up... I didn't need it in this case so it wasn't an issue.
i understand now.
i that case, (entnext ent) would just returnn nil - then you know you're
at the end
