Visual LISP, AutoLISP and General Customization
Is layer filter list auto generated?
5 REPLIES 5
247 Views, 5 Replies
Hi all,
is the layer filter's list auto-generated?
I'd used the lisp to clear the layer filter list, but, the next time i open
the same drawing, all the filters come back again!
Is there any variable to disable this feature? When i open so drawing i have
to clear the filter list and then create the filter i want to use, or, is
there an improved version of the LayerFiltersDelete lisp whereby i can make
selection thru a list of filter.
Thanks in advance.
Koh
ps the layerfiltersdelete i'm using obtained from this newsgroup.
5 REPLIES 5
Have you cleared the layer filters from the XRefs themselves?
R. Robert Bell, MCSE
www.AcadX.com
"Ah Koh" wrote in message
news:8FF9623CF83F64A6FC83F3BE4A734FBA@in.WebX.maYIadrTaRb...
| Hi all,
open
have
make
| Thanks in advance.
| Koh
Nope, there is no xref!
Koh
"R. Robert Bell" wrote in message
news:A1AA50AAF10142FBF96B50000800F628@in.WebX.maYIadrTaRb...
> www.AcadX.com
> | Hi all,
> open
> have
is
> make
> | Thanks in advance.
> | Koh
Layer filters are "inherited" from anything used in the DWG... xrefs,
blocks, templates.
Each of those must be purged to get a true handle on your filters (UGH!)
Workaround:
There is a method to purge all filters (do a search on this NG) - use it,
and "import" desired filters from a block or template.
Note to Autodesk... don't ever make such a mess of our dwgs again .
Learn something today.
Now using the Smartpurger to purge all drawing's filters.
Cheers.
"PF" wrote in message
news:AB8EE86D8A2715BD104233D50B19F759@in.WebX.maYIadrTaRb...
> blocks, templates.
> Workaround:
One more thing I may not have been clear on...
"Layer filters are "inherited" from anything used in the DWG... xrefs,
blocks, templates.
Each of those must be purged to get a true handle on your filters (UGH!)"
Each Block and Template must be purged... and the Dwg you're editing....
And I have not tried the results of
* re-defining blocks via wblock
* inserting blocks 'exploded'
Nevertheless... lots of unwanted filters are accumulated in time.
”Boost
