*Rutledge, Phillip
Message 1 of 8 (82 Views)
Is it possible to add EED to a viewport entity
82 Views, 7 Replies
09-26-2002 05:41 AM
Hi there,
I tried to add extended entity data to a viewport but it didn't seem to
work. I noticed that ACAD already has EED attached. Can I not do this?
Thanks in advance for your help.
Phillip
*Jones, Bobby C.
Message 2 of 8 (82 Views)
Re: Is it possible to add EED to a viewport entity
09-26-2002 05:57 AM in reply to: *Rutledge, Phillip
You must use ActiveX automation to do this. Here are a couple of routines
that I developed for the purpose of adding xdata to vports.
http://code.acadx.com/visuallisp/041.htm
http://code.acadx.com/visuallisp/042.htm
Bobby C. Jones
www.AcadX.com
*per
Message 3 of 8 (82 Views)
Re:
09-26-2002 09:57 PM in reply to: *Rutledge, Phillip
Thanks Bobby,
I'll give them a go. Nice site you have there too. Keep up the good work.
Phillip
"Bobby C. Jones" wrote in message
news:EBBE2B8D3E7237245A69E3F5F7F727F9@in.WebX.maYIadrTaRb...
routines
> Bobby C. Jones
> www.AcadX.com
*per
Message 4 of 8 (82 Views)
Re:
09-26-2002 11:15 PM in reply to: *Rutledge, Phillip
Hi Bobby,
Well this isn't going to be as easy as I had (thought) or hoped given my
VERY limited knowledge of activeX.
In your function ax:smileytongue:utXData, there are two arguments required (vlaObj &
XData).
1. What is the vlaObj? Is that the entity name?
2. XData - Don't I need to supply the APPID as well?
If you don't have the time to explain, I'll understand. I can see I need to
read-up more on the subject.
Phillip
routines
> Bobby C. Jones
> www.AcadX.com
*per
Message 5 of 8 (82 Views)
Re:
09-26-2002 11:40 PM in reply to: *Rutledge, Phillip
Ok, I kinda' understand now about the vlaObj question I had. I see how to
convert an entity name to an ActiveX Object.
I'm not sure though why I don't need the APPID in PutXData... or do I?
Phillip
"per" wrote in message
news:C99EDB6017B41FE53ECA72B6E5DD501D@in.WebX.maYIadrTaRb...
> Hi Bobby,
> XData).
to
> Phillip
> routines
> > Bobby C. Jones
> > www.AcadX.com
*Jones, Bobby C.
Message 6 of 8 (82 Views)
Re:
09-26-2002 11:47 PM in reply to: *Rutledge, Phillip
Hello Phillip,
Time is short these days, but I'll see if I can help shed some light. The
vlaObj argument expects an ActiveX object. Visual LISP provides you a
simple way to convert entity names into ActiveX objects with the
(vlax-ename->vla-object ...) function:
(setq vpEntity (car (entsel "Select a floating viewport: "))
vla:vpEntity (vlax-ename->vla-object vpEntity))
If you successfully select a floating viewport, vla:vpEntity will contain a
reference to your ActiveX viewport object. Feed it to ax:GetXdata and
observe what it returns:
(ax:GetXdata vla:vpEntity "ACAD")
Returns something similar to this:
((1001 . "ACAD")
(1000 . "MVIEW")
(1002 . "{")
(1070 . 16)
(1010 0.0 0.0 0.0)
(1010 0.0 0.0 1.0)
(1040 . 0.0)
(1040 . 1384.78)
(1002 . "{")
(1003 . "A-Area-Bdry")
(1003 . "S-Roof-Trus")
(1002 . "}")
(1002 . "}")
Notice that the 1001 key contains the AppID. This is how you will need to
structure your xdata list to feed to ax:smileytongue:utXdata. Be careful here! Unlike
the LISP method for storing xdata on an object, the ActiveX method will
automatically register your AppID if it's not already. A misspelled AppID
could cause you a lot of grief later.
I showed you one simple method of obtaining an ActiveX object. There are
others and the whole topic of Visual LISP's implementation of ActiveX is a
very broad topic. If you have other questions please ask. There are many
in this group whom are willing and more than able to help. Good luck.
Bobby C. Jones
www.AcadX.com
*per
Message 7 of 8 (82 Views)
Re:
09-27-2002 12:13 AM in reply to: *Rutledge, Phillip
The 1001 key... Ahhhh, the missing link... I see said the blind man. Thanks
so much Bobby.
Have a great weekend.
Phillip
news:3369DA7E3B1236028563BA4D5C766691@in.WebX.maYIadrTaRb...
> Hello Phillip,
a
> ((1001 . "ACAD")
> (1000 . "MVIEW")
> (1002 . "{")
> (1070 . 16)
> (1010 0.0 0.0 0.0)
> (1010 0.0 0.0 1.0)
> (1040 . 0.0)
> (1040 . 1384.78)
> (1002 . "{")
> (1002 . "}")
> (1002 . "}")
Unlike
> Bobby C. Jones
> www.AcadX.com
*Jones, Bobby C.
Message 8 of 8 (82 Views)
Re:
09-27-2002 12:29 AM in reply to: *Rutledge, Phillip
Thanks..you too.
Bobby C. Jones
www.AcadX.com
news:4193F584E2155BB813F784FDC5A68596@in.WebX.maYIadrTaRb...
> so much Bobby.
> Phillip
You are not logged in.
Ask the Community
