mid-awe
Message 1 of 20 (626 Views)
Invisible Attribute Constant Dynamic Block Visibility State?
626 Views, 19 Replies
01-24-2013 07:07 AM
Hi all,
I have a dynamic block with several visibility states, and each visibility state has one invisible-constant attribute. I can't seem to wrap my head around dynamic blocks well enough to get the value from the active visibility state invisible constant attribute. I know how to get the visibility state like this:
(setq ss (ssget "_x" (list '(0 . "INSERT") '(2 . "`*U*,<DynBlockName>") (cons 410 (getvar 'ctab)))))
 but what next?
Thank you.
mid-awe
Message 2 of 20 (602 Views)
Re: Invisible Attribute Constant Dynamic Block Visibility State?
01-25-2013 06:55 AM in reply to: mid-awe
Seeing that there has been no suggestions I'm wondering if I'm going about this the wrong way. Is there a better way to get information about the drawing in the visibility state of the dynamic block?
I am inserting a dynamic block with several plants each in a seperate visibility state. I need the botanical name of the visible plant. I have placed that information in the invisible attribute but if there is a better way where I can get that information when I need it, then I am open to any suggestion.
Thank you.
pbejse
Message 3 of 20 (599 Views)
01-25-2013 07:00 AM in reply to: mid-awe
Thank you.
Interesting , I'll have a look-see tomrrw mid-awe
Hang in there.
:smileyhappy:
mid-awe
Message 4 of 20 (586 Views)
01-25-2013 09:23 AM in reply to: pbejse
Thank you pbejse, I'm standing still. Completely stumped after I dxf dumped the dblock and found no clues, but alas, I haven't worked with dynamic blocks much in the past. I'm eager to hear what you find. Thank you again. :smileyhappy:
pbejse
Message 5 of 20 (573 Views)
01-25-2013 10:58 PM in reply to: mid-awe
mid-awe,
It can be done with invisible attributes. but i need a sample of your DB to write a custom made code to work on your blocks.
Or you can use dictionary , like the ones you had before.
Your choice
:smileyhappy:
mid-awe
Message 6 of 20 (560 Views)
01-27-2013 07:03 AM in reply to: pbejse
That sounds encouraging :smileyhappy:
I've attached a sample of my DB
Thank you very much.
pbejse
Message 7 of 20 (548 Views)
01-27-2013 08:07 PM in reply to: mid-awe
That is not a Dynamic block, anyhoo, The thread title says Invisible Constant, hence the value is always the same for depending on the  Visibility state.
Block name FruitBasket
Visibilty state: Mango
Constant/Invisible Attribute value :Ripe
Visibilty state: Banana
Constant/Invisible Attribute value :Green
is that how you want it?
mid-awe
Message 8 of 20 (545 Views)
01-27-2013 08:20 PM in reply to: pbejse
Oh, I don't have a recent version of ACAD here on the weekends. I just sent a backup copy of the block I assumed it was correct. :smileyembarrassed:
Yeah, you seem to have the idea of what I going for.
pbejse
Message 9 of 20 (536 Views)
01-27-2013 09:42 PM in reply to: mid-awe
In that case you dont need to create an invisible/contstant attribute for every Visibility states, one is enough and it has all the data for every Visibiltiy name
Attribute string:
"(\"BANANA\" \"LONG\") (\"MANGO\" \"RIPE\") (\"EGG\" \"HARD BOILED\")"
(setq data
(read (strcat "(" (vla-get-textstring (extracted attribute) ")"))
Now depending on the visibility name:
ex. current block visibility : MANGO
(assoc "MANGO" data)
("MANGO" "RIPE");<-- RIPE being the data
simple eh?
HTH
mid-awe
Message 10 of 20 (521 Views)
01-28-2013 06:52 AM in reply to: pbejse
That does seem simple, but it could take several days to change all of the dynamic blocks to that format. To be honest I'm  strapped for time now and if it's possible to get the value of the invisible/contstant attribute for each Visibility state it would help out a lot. Also, I only need the value from the active visibility state.
I will use this in conjunction with my block counting code so that as the blocks are counted the values of the visibility state along with the botanical names can be stored into the dictionary to build the legend.
I'm back at my desk this morning so I'm attaching the correct version of the block I attached earlier. (just in the case that it may help.)
Thank you again this is a big help. :smileyhappy:
You are not logged in.
Ask the Community
