Visual LISP, AutoLISP and General Customization
Inserting Lisp into Fields
1 REPLY 1
439 Views, 1 Reply
I have a lisp routine:
(defun getLayout (pos / result cLayout layouts^ i len)
; pos = -1 return previuous layout name
; pos =  0 return current   layout name
; pos =  1 return next      layout name
(cond
  ((zerop pos)
   (setq result (getvar "ctab"))
  ); case
  ((eq (getvar "ctab") "Model")
  ); case
  ( t
   (setq cLayout (getvar "ctab"))
   (setq layouts^ (layoutlist))
   (setq len (length layouts^))
   (if (member cLayout layouts^)
    (progn
     (setq i (vl-position cLayout layouts^))
     (cond
      ((= pos -1)
       (if (> i 0)
        (setq result (nth (1- i) layouts^))
        (setq result "")
       ); if
      ); case
      ((= pos 1)
       (if (< i (1- len))
        (setq result (nth (1+ i) layouts^))
        (setq result "")
       ); if
      ); case
      ( t ; invalid argument code
       (setq result "")
      ); case
     ); cond
    ); progn
    (setq result "")
   ); if
  ); case
); cond
result
which basically returns either the current, previous or next tab name depending on what you call up. Does someone know a way to link this lisp to a field? I am doing some plan and profile drawings which contain match lines I would like to have the match line text automated. For example if I'm on layout called PP02 there would be two match lines in the drawing one would read MATCH LINE PP01 and the other would read MATCH LINE PP03 this lisp routine returns the correct variable but how do I loink this to a fiels? Thanks
1 REPLY 1
scot-65
Wow, another question on how to display user information in a field.
You say you have match lines on a page and you want to label these match lines?
One way is to assign the "result" of the left-side match line to USERS1 and the
"result" of the right-side match line to USERS2. Then in the field expression simply
use $(getvar,USERS1), $(getvar,USERS2).
Another method is to create a user gremlin. Remove "result" from your opening defun:
I would suggest renaming "result" to something more in tune with the routine's name
as part of the gremlin's name. I use the following format - USER+RoutineName+Key.
Where "Key" is an optional suffix if needed (in your case it would be Previous and Next).
Once the gremlin is set free, you can find it in the list of declared variables in the field
dialog list box.
I do not have enough experience with layout tabs to tell you how to automate the LISP
expression when switching tabs with the pointing device (mouse).
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
”Boost
