Visual LISP, AutoLISP and General Customization
Insert point at every block
14 REPLIES 14
Message 1 of 15
RocksterB
713 Views, 14 Replies
I need a routine that inserts a point at the insert point or block named "Insert_Point" at every block in the file. The routine could use the current layer, which would be set prior to starting the routine. If it could request the user for the PDMode value and PDSize that would be great too. This will assist me in creating block libraries. Thanks in advance.
14 REPLIES 14
Message 2 of 15
BlackBox_
in reply to: RocksterB
You should be able to pull what you need from this thread:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/insert-point-at-list-block-and-dinami...
"How we think determines what we do, and what we do determines what we get."
Message 3 of 15
3wood
Many years ago, before AutoDesk Design Center was born, I had been using a routine named BLOCKMAN. It creates image for blocks in a library and put a red cross at the insert point in the image.
Message 4 of 15
hmsilva
randy,
to insert a point at the insertion point at every blocks in the file,
perhaps something like this
(defun c:test (/ ent itm num pdm pds ss)
  (if (setq ss (ssget "_X" '((0 . "INSERT"))))
    (progn
      (while (= (member pdm '(0 1 2 3 4 32 33 34 35 36 64 65 66 67 68 96 97 98 99 100)) nil)
	(setq pdm (getint
		    (strcat "\Enter new value for PDMODE <"(rtos (getvar "pdmode"))">: ")))
	(if (null pdm)
	  (setq pdm (getvar "pdmode"))
	);; if
	(if (= (member pdm '(0 1 2 3 4 32 33 34 35 36 64 65 66 67 68 96 97 98 99 100)) nil)
	  (progn
	    (prompt "\nRequires one of these values: 0,1,2,3,4,32,33,34,35,36,64,65,66,67,68,96,97,98,99 or 100.\n")
	    (setq pdm nil)
	  );; progn
	);; if
      );; while
      (setq pds	(getint
		  (strcat "\Enter new value for PDSIZE <"(rtos (getvar "pdsize"))">: ")))
      (if (null pds)
	(setq pds (getvar "pdsize"))
      ;; if
      (setvar "pdmode" pdm)
      (setvar "pdsize" pds)
      (setq itm	0
	    num	(sslength ss)
      (while (< itm num)
	(setq ent (entget (ssname ss itm)))
	(if
	  (/= (logand 4 (cdr (assoc 70 (tblsearch "block" (cdr (assoc 2 ent))))))4)
	   (progn
	     (entmakex (list (cons 0 "POINT")
			     (cons 10 (cdr (assoc 10 ent)))
			     (cons 410 (cdr (assoc 410 ent)))
	   );; progn
	);; if
	(setq itm (1+ itm))
      );; while
    );; progn
  );; if
);; test
 hope that helps
Henrique
Message 5 of 15
RocksterB
in reply to: 3wood
I saw BlockMan going to $95 bucks. Is this the one you previously used?
Henrique, I'll give your routine a try on Monday.
Message 6 of 15
_Tharwat
in reply to: hmsilva
@ Henrique
There is no need to reconstruct the same dxf code two times .
This ...
 is enough with this .
(assoc 410 ent)
Message 7 of 15
hmsilva
in reply to: _Tharwat
Tharwat,
attentive, as always, and absolutely correct...
Cheers
Henrique
Message 8 of 15
RocksterB
That was just what I needed. Thanks again!
Message 9 of 15
hmsilva
You're welcome, randy
glad i could help
Henrique
Message 10 of 15
pbejse
Not sure, but why not incorporate the "point" entitiy on the block
(defun C:adp (/ ss a)
    (command "_ddptype")
    (if (setq ss (ssget '((0 . "INSERT"))))
      (repeat (setq i (sslength ss))
       (if
          (not (member (setq
                         bn (Vla-get-effectivename
                              (vlax-ename->vla-object (ssname ss (setq i (1- i))))
                       data
           (vla-addpoint
               (cdr
                 (assoc 330 (entget (tblobjname "BLOCK" bn)))
             (vlax-3D-point 0 0)
    (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acAllViewports
Message 11 of 15
_Tharwat
in reply to: pbejse
   (if (not (member bn data))
        (progn
          (setq data (cons bn data))
           (vla-addpoint
Out of offense , The above part was missing  Smiley Wink
Message 12 of 15
pbejse
Indeed it is , Good catchTharwat
Thanks dude
Message 13 of 15
RocksterB
in reply to: pbejse
Although applying the point to the block sounds good in theory, it problematic in practice. There are various design reasons why a user may have to display points by their style in their design file. I wouldn't want their design points to interfere with the point in a block. Good thinking out of the box though.Smiley Wink
Tharwat, exactly where do I put those additional code line?
Message 14 of 15
_Tharwat
All creadit goes to pbejse Smiley Happy
(defun c:test (/ ss i bn lst)
  (or doc
      (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
      (if
        (not (member (setq
                       bn
                     lst
         (progn
           (setq lst (cons bn lst))
           (vla-addpoint
             (vla-item (vla-get-blocks doc) bn)
             (vlax-3D-point 0 0)
  (vla-regen doc
             acAllViewports
  (princ)
(vl-load-com)
Message 15 of 15
RocksterB
in reply to: pbejse
Thank you!
”Boost
