Visual LISP, AutoLISP and General Customization
Insert menu item on pulldown menu
2 REPLIES 2
217 Views, 2 Replies
I have loaded a menu group and wish to add a menu to the menu bar using
lisp. The menu group is called
GISMaster and the menu is called GISMaster.
I previously used
(menucmd "P14=+GISMaster.GISMaster")
and this worked OK. When I upgraded to Windows XP (Still using ACAD2000i)
the command returns a "nil" and does not load the menu.
Herewith the first few lines of the MNU file:
***MENUGROUP=GISMaster
***POP1
[/GGISMaster]
[->/aLayer Tools]
[->/CCreate GISMaster Layers]
[/SCollection System (SY)]^C^C(command "_.layer" "n" "sy_" "s" "sy_"
I loaded the menu with:
(defun c:GISM ()
(ARXLOAD "C:\\Program Files\\GISMaster\\gism30_2000.arx")
(command "._MENULOAD" "C:\\Program Files\\GISMaster\\gism30_2000.mns")
Any assistance will be appreciated.
Regards
Sean Bartleet
2 REPLIES 2
Try this:
(menucmd "P14=+GISMaster.POP1")
Your menu you want to add is not named or labeled GISMaster. If that
doesn't work I'll give it a look at on XP at home tonight.
Kevin Nehls
"Sean Bartleet" wrote in message
news:B161170A5944E6B967A1F75DE1774192@in.WebX.maYIadrTaRb...
> Hi,
> I previously used
Thanks, it worked great. I now see as you say, no alias was defined for the
menu.
Thanks for the help.
Sean
"Kevin Nehls" wrote in message
news:E58F4BB471D6989D90A54C15E6C7AE2C@in.WebX.maYIadrTaRb...
> Try this:
> Kevin Nehls
”Boost
