Insert block to multiple layouts
6 REPLIES 6
3052 Views, 6 Replies
I'm trying to insert a block into 5 different layouts at one time. Is it possible to do this without changing from layout to layout and inserting each time.
At the moment I was thinking of changing CTAB to the relevant layout and then inserting at a fixed location. Is there a better way to do it. I'm only using autolisp (no vlisp).
6 REPLIES 6
If you're inserting with (command "insert" ...
I think you'll have to set each layout current and then insert.
If you're entmaking the inserts you wouldn't need to set layouts current.
"smjgsmith" wrote in message
news:f18fbd5.-1@WebX.maYIadrTaRb...
each time.
Thanks for the info Mark
This is what I came up with:-
(foreach layout (layoutlist)
(setvar "ctab" layout)
(command "-insert" "sign-001" "107.2,46.2,0.0" "" "" "")
);foreach
Is it possible to suppress the regen as you change tabs??
news:f18fbd5.2@WebX.maYIadrTaRb...
> );foreach
Not sure, you can try setting Regenauto to off but i don't know if that will
prompt you each time or just bypass the regen.
try this....no regens except to set the first layout current, if the
block isn't already defined in the drawing it will insert it, providing
it is found in the current search path.
;| Code to insert a block in all PS Tabs in the same place,
By Jeff Mishler 10/2/03
usage:
(tabs_insert "titlesheet" '(10.0 20.0 0.0)) |;
(defun tabs_insert (bname inspt / )
;(setq inspt '(107.2 46.2 0.0)) ; can hard code insertion point here,
; just remove inspt from first line and don't enter the 2nd arg at
command
(setvar "ctab" (car (layoutlist)));sets current tab to first in list
(foreach x (layoutlist); cycle thru all tabs
(if (not (tblsearch "block" bname)); see if block is defined
(command "_.-insert" bname inspt "0" "" ""); nope, insert it
;else
(progn ;entmake insert to eliminate switching tabs
(entmake (list '(0 . "INSERT")
'(100 . "AcDbEntity")
'(67 . 1); insert in PS
(cons 410 x); tab name
'(8 . "0"); change this to the layer you want
'(100 . "AcDbBlockReference")
'(66 . 0); no attributes follow
(cons 2 bname); block name
(cons 10 inspt); insertion point
'(41 . 1.0) '(42 . 1.0) '(43 . 1.0);scale factors
'(50 . 0.0) ;rotation
'(70 . 0) '(71 . 0) '(44 . 0.0)'(45 . 0.0)
'(210 0.0 0.0 1.0)
);list
);entmake
);progn
);if
);foreach
(princ)
);defun
> );foreach
Mihai.Tanase
Sorry
i am pretty new to lisp and to this community but beacuase it looks alot like something tht i am looking for i just have to ask :
How can it be done as a separate command? and to have it look for the block in another folder?Smiley Tongue
Tanks
”Boost
