Visual LISP, AutoLISP and General Customization
Insert block name as attribute
6 REPLIES 6
jonmcfarlandGY
431 Views, 6 Replies
My AutoLISP is a bit rusty so I apologize if this has an easy answer.
I'm trying to write a routine that lets the user select block A and then inserts block B (a tag) using block A's name and the (only) attribute.  I've managed to extract the first block's name using:
       (setq ent (nentsel))
       (setq blk-name (vla-get-EffectiveName (vlax-ename->vla-object (last (last ent)))))
But when I try to insert the block, I can't get block A's name (as returned by blk-name) as the attribute text using
       (Command -insert _tag-part 0,0,0 48 48 0 blk-name)
   it fails.  I think the attribute parameter (blk-name) is causing the problem because it's not in the form of a string.  Any suggestions to get this to work?
Jon
Jon
Please select "Accept as Solution" if your question was answered
6 REPLIES 6
_Tharwat
in reply to: jonmcfarlandGY
For your first code to get the real name of the selected block ..
Try ...
       (setq blk-name (vla-get-EffectiveName (vlax-ename->vla-object (car ent))))
jonmcfarlandGY
in reply to: _Tharwat
Thanks, but when I use
    and pick the block "breakline it returns "Select object: ; error: ActiveX Server returned the error: unknown name:
EffectiveName"
When I use
  it returns""breakline"".  Is there something going on that I'm not seeing?
Jon
Jon
_Tharwat
You should add the following code to your file and load it to activate the Active x codes .
(vl-load-com)
_Tharwat
I have just noticed that you are using the function *nentsel* which enter a definition and it is not the proper function for you needs , so just use function *entsel* instead of *nentsel*
jonmcfarlandGY
Thanks, that helped a lot.  My code needs to be fleshed out but this helped.
Thanks again,
Jpn
Jon
_Tharwat
You're welcome any time .
Tharwat
”Boost
