Insert block into several drawings
3 REPLIES 3
487 Views, 3 Replies
Does anyone know of a way to insert a block onto many different drawings quickly?
I have a title block I need to insert into about 100 drawings. It seems very tedious to open each drawing and insert 100 times. Ideas?
3 REPLIES 3
Lee_Mac
You could try my Copy to Drawings program.
However, note that since the program uses ObjectDBX to interface directly with the drawing database of each drawing without opening the drawing in the AutoCAD Editor, the drawings will be saved to native format (that is, the highest version available in the host application) - this is a known bug of using the ActiveX saveas method in conjunction with ObjectDBX.
I hope the program is of use nonetheless.
in reply to: Lee_Mac
Wow, thats amazing! Thank you!
Lee_Mac
You're welcome, thanks!
”Boost
