• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Insert block at intersection
    937 Views, 6 Replies
    06-22-2011 08:10 AM
    Does anyone know of a lisp that will insert a block at the intersection points of multiple lines or polylines? Basically it would ask you to select polylines or lines, then check to see where their intersections are with each other and insert a block at those points. See the attached image for what I am looking for.
    Please use plain text.
    Re: Insert block at intersection
    06-22-2011 02:09 PM in reply to: jbear0000
    Two ways, starting with ssget "c" or "f":
    1. Close the pline, by pedit if the ends are close enough, or add a pline to do so, and use it to ssget the crossing 'yellow' lines, and find the on-seg intersections of them with the pline; or
    2. process each segment of the pline with a narrow ssget to find the crossing lines in that segment, so on.
    S
    06-22-2011 05:02 PM in reply to: jbear0000
    Please , you attach here drawing file
    one demonstration...
    I use this file ( who attached) for make you program requested LISP/ARX..
    Thanks...........
    Valued Mentor
    06-23-2011 12:53 AM in reply to: jbear0000
    How's about this? Pick the main line (red), pick the crossing lines (yellow) and Bob's your aunty.
    S
    (defun c:sbx ( / )
      (progn
        (setq ent (car (entsel "\nSelect main line: ")))
        (if ent
          (progn
     (princ "\nSelect crossing line(s): ")
     (if (setq ss (ssget))
       (progn
         (setq count 0
        obj (vlax-ename->vla-object ent)
        pointlist nil
         (repeat (sslength ss)
           (setq xent (ssname ss count)
          xobj (vlax-ename->vla-object xent)
           (if (setq int (vla-IntersectWith obj xobj acExtendNone))
      (progn
        (setq int (vlax-safearray->list (vlax-variant-value int))
       pointlist (append pointlist (list int))
           (setq count (1+ count))
         (if (null (tblobjname "BLOCK" "SBblock"))
           (progn
      (entmake (list (cons 0 "BLOCK") (cons 2 "SBblock") (cons 70 0) (list 10 0.0 0.0 0.0)))
      (entmake '((0 . "LWPOLYLINE") (100 . "AcDbEntity") (8 . "0") (100 . "AcDbPolyline") (90 . 2) (70 . 1) (43 . 1.0) (38 . 0.0) (39 . 0.0)
          (10 2.5 0.0) (40 . 1.0) (41 . 1.0) (42 . 1.0) (91 . 0)
          (10 -2.5 0.0) (40 . 1.0) (41 . 1.0) (42 . 1.0) (91 . 0)
          (210 0.0 0.0 1.0)
      (setq blockname (entmake '((0 . "ENDBLK"))))
         (foreach pt_nth pointlist
           (entmake (append
        '((0 . "INSERT") (100 . "AcDbEntity") (8 . "0") (100 . "AcDbBlockReference") (2 . "SBblock"))
        (list (cons 10 pt_nth))
        '((41 . 1.0) (42 . 1.0) (43 . 1.0) (50 . 0.0) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 1.0))
      (princ)
    Hallex
    06-23-2011 05:18 AM in reply to: scottbolton
    Good work,
    Just forgot to add
    (vl-load-com) at the start of code,
    do edition, please,
    Regards
    :smileyhappy:
    06-23-2011 05:34 AM in reply to: scottbolton
    Thanks scottbolton, that works great. I simiply changed the block name in the lisp and added (vl-load-com) to the beginning as Hallex pointed out and it worked. Thanks for the help.
    Valued Mentor
    06-23-2011 05:38 AM in reply to: jbear0000
    You're welcome.
    I use many vl-commands in many routines and so I have (vl-load-com) in my acaddoc.lsp.
    S
