• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Dewlevlak
    Re: Insert Dynamic Block programmatically
    06-12-2012 07:57 AM in reply to: kbeake
    Thank you for your quick reply.  I am trying it without success.  Here is a sample file with a simple line block which has a length paramerter 'TheLength'.  I would like to be able to change all of these lengths with LISP all at once. Then, I can train a Button to automatically change all these parameters in the drawing.  I am able to change the lenth of one block selection at a time with (setq obj (car (entsel))).
    Thanks again,
    Please use plain text.
    *Expert Elite*
    06-12-2012 08:40 AM in reply to: Dewlevlak
    Thanks again,
    Guess i need to put it together for you then.
    (defun c:chpname  ( / ChangePropertyLength  objs ename)
     (vl-load-com)
     ;;; Generic sub for property name  ;;;
     (defun ChangePropertyLength  (ent pnme len / props name)
          (setq props (vlax-invoke ent 'getdynamicblockproperties))
          (foreach  prop  props
                (if
                      (eq (strcase (vla-get-propertyname prop)) (strcase pnme))
                           (vla-put-value prop len)
      (if (and
     (setq TheLength
               (cond  ((getdist
                            (strcat "\nEnter Length <"
                                    (rtos (setq TheLength
                                                     (cond (TheLength) (1.00))
                                                ) 2 2 )  ">: " )))
                     (TheLength)))
                (setq objs (ssget ":L" '((0 . "INSERT")))))
            (repeat (setq i (sslength objs))
                  (setq ename (vlax-ename->vla-object
                                    (ssname objs
                                            (setq i (1- i)))))
                  (ChangePropertyLength
                        ename  "TheLength" TheLength))
    There are many ways to write this code, but i opted not to deviate from the orignal.
    HTH
    Dewlevlak
    06-12-2012 09:05 AM in reply to: Dewlevlak
    :smileyhappy Oh Sweet!  That is so AWESOME!  Thank you!  Thank you! Thank you!  That works great!
    I will go through it to try to understand how it all works.  But it does work in the drawings the way I needed it to! :smileyvery-happy:
    Dewlevlak
    09-14-2012 01:04 PM in reply to: pbejse
    Hello again
    Thank you, your help has been very  helpful.  I have been able to modify and use your program to modify all parameters of blocks in the drawing for different purposes.  I have come across another situation to which I need help.
    I would like to change the "Visibility" of blocks nested in another block.  I have a block in the drawing which has 3 blocks nested in it.  How do I selet the nested blocks within a particular block to be changed?
    Thanks again,
    *Expert Elite*
    09-14-2012 04:59 PM in reply to: Dewlevlak
    Thanks again,
    As it affect every instance of the block in the drawing might as well Bedit or Refedit the block then run the code there.
    Dewlevlak
    09-18-2012 12:49 PM in reply to: pbejse
    Thank you, that worked slick. Sometimes it is easy when programing to forget the simple used all the time AutoCAD commands.
