Visual LISP, AutoLISP and General Customization
Importing Wall styles
6 REPLIES 6
218 Views, 6 Replies
In ADT 2.0 is it possible to import several wall
styles from a template with a lisp routine?  I am trying to create a
routine to redefine existing wall styles since a lot of our old drawings were
using messed up wall styles.
6 REPLIES 6
Ender,
The only way to import specific Aec Objects is via
DBX .  Or you can save your default template file as a drawing. I have one
called AecStyleFile.dwg.
Then add this line to your Acad2000doc.lsp
file
(if (not (tblsearch (namedobjdict)
"AEC_WALL_STYLES")
    (progn
    (command "_.insert"
"YourFileName")
    (command "_.explode" (entlast)
let me know how it goes.
Rob
Starz
Stardsign cad solutions
iC - AEC Information Center
href="http://www.stardsign.com/aecic.html">www.stardsign.com/aecic.html
LayerX
beta testers needed...
href="http://www.stardsign.com/beta_programs.htm">www.stardsign.com/beta_programs.htm
jbuzbee
Yes it is, however, it requires some pretty advanced code. How in-depth is your knowledge of the ActiveX extensions exposed in AutoLISP for 2000+? Here is a road map: 1. You will first need to create a routine that access the ObjectDBX Interface to "open" the "template drawing". 2. Access the dictionary collection of the opened DBX document and look for "AEC_WALL_STYLES". 3. At this point you can search for individual "styles" as defined in the dictionary. 4. Once you have found the entity of the style you want to "import" you need to use the "vla-copy" method to copy the dictionary from the DBX document to the active document. 5. VERY IMPORTANT: at this point you need to release everything or your program will crash AutoCAD. I'm not trying to scare you away from attempting this, just let you know ahead of time what your in for. You might want to check with Peter Funk over at the ADT customization NG for a VBA equivalent - if it even can be done in VBA. James Buzbee
This creates wall styles right?  I'm trying to
redefine existing wall styles.  Your routine won't redefine
existing wall styles, will it?
Ender,
via DBX .  Or you can save your default template file as a drawing. I
have one called AecStyleFile.dwg.
file
"AEC_WALL_STYLES")
    (progn
    (command "_.insert"
"YourFileName")
Rob
Starz
LayerX
wall styles from a template with a lisp routine?  I am trying to create
a routine to redefine existing wall styles since a lot of our old drawings
were using messed up wall
styles.
didn't read it fully.  No this will not update
your styles.
read Jims post.  DBX is lots of
fun.
Rob
Starz
LayerX
to redefine existing wall styles.  Your routine won't redefine
Ender,
file
"AEC_WALL_STYLES")
    (progn
    (command "_.insert"
"YourFileName")
(entlast) "")
Rob
Starz
LayerX
create a routine to redefine existing wall styles since a lot of our old
drawings were using messed up wall
styles.
Ahhh.  No my knowledge do be limited.  I
think maybe I can use the command line version to actually edit the existing
wall styles.  Only thing is I won't be able to change the hatches.
Here's the simple code I have.  It only allows one component, but I believe
I can add extra if I will need it.  Right now I don't.  My main
problem was with component priorities.  So this updates those.
(defun definewall (W_NAME W_END_1 W_END_2
W_COMP_1_N W_COMP_1_P)
  (COMMAND "-AECWALLSTYLE"
"EDIT"      W_NAME
"ENDCAP"
    W_END_1
W_END_2    "COMPONENT" "E"
"1"
    "NAME"      W_COMP_1_N
"PRIORITY"  W_COMP_1_P  ""
I will use it like:
(DEFINEWALL "NEW WALL" "STANDARD" "STANDARD"
"GYP" "1201")
Thanks for all your help guys.  I might try
the more advanced languages one day, but not now.
Yes
Buzbee
Jim,
I have been DBX'ing in styles but I never checked
to see if Existing styles were updated...so I tried it.  From what I have
gotten it is not updating existing styles.
Are you getting differrent results?
Rob
Starz
LayerX
”Boost
