• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    The_Caddie
    If else when checking for registry key
    124 Views, 2 Replies
    10-12-2012 01:06 AM
    I want to create a registry key using lisp but only if it dost already exist I know how to use the IF else function and how to create a registry key using lisp but not sure on how to check for the existence of a registry key with in a lisp program?
    Please use plain text.
    Re: If else when checking for registry key
    10-12-2012 01:19 AM in reply to: The_Caddie
    vl-registry-read
    vl-registry-write
    vl-registry-delete
    or
    GETENV and SETENV me thinks
    HTH
    10-12-2012 01:43 PM in reply to: The_Caddie
    I think vl-registry-write will only make the key if it doesn't exist. Or, rather I should say, you will not lose any values already in that key by using vl-registry-write to try to create it.
    So, why check first? (Unless you mean a registry "VALUE" or "DATA" and not "KEY")
    Example:
    Command: (vl-registry-read "HKEY_CURRENT_USER\\TestA")
    nil
    Key does not exist
    Command: (vl-registry-write "HKEY_CURRENT_USER\\TestA")
    T
    Now it does but has no values
    nil
    read fails because it looks for a value
    Command: (vl-registry-write "HKEY_CURRENT_USER\\TestA" "" "default-value")
    "default-value"
    I add a value
    "default-value"
    It reads a value
    T
    I re-write the key
    "default-value"
    value is still there
    fugetaboutit
