I have a situation where the user can pick litturally 10's of diffrent sizes of a particular product. the user would thus be very bright to remember every single size. the idea I had was to create a lisp that promts the user for a size, if equal go to insert the block of that size, if less than x but greater than y prompt the user that bla is the closes size available
eg of prompt:
Your specifide size of 102mm is not available, the closest mesurment is 100mm would you like to use this instead?: [yes/ No] <yes>:
the code i had a look at and was thinking of is the following:
(defun c:testand () (setq a (getreal "\nEnter a Number : ")) (if (and (>= a 5.0) (<= a 10.0) );and (prompt "\nNumber is between 5 and 10") (prompt "\nNumber is less than 5 or greater than 10") );if (princ) );defun (princ)
However i tried to modify this to the following but to no avail?
(defun c:testand () (setq a (getreal "\nEnter a hight : ")) (if (and (= a 100.0) ((>= a 100.0)<= a 110) );and (prompt "\nNumber is 100") (prompt "\nNumber is between 100 and 110") );if (princ) );defun (princ)
but this dose not cater for numbers in a way that says if greater than but less than (eg: if greater than 100 but less than 110, then do or goto)?
Try starting with this.
(defun c:testand () (setq a (getreal "\nEnter a hight : ")) (cond (;cond1 (= a 100.0) (prompt "\nNumber is 100") );cond1 (;cond2 (and (> a 100.0) (<= a 110)) (prompt "\nNumber is between 100 and 110") );cond2 );cond (princ) );defun
Something like this perhaps
(defun c:test ( / a ans) (initget 6) (if (and (setq a (getreal "\nEnter a Number <exit>: ")) (= (type a) 'REAL) ) (cond ((and (<= 5.0 a 10.0) (/= a 7.5)) (prompt (strcat "\nYour specifide size of " (rtos a) "mm is not available, " )) (initget "Yes No") (setq ans (getkword "would you like to use 7.5 instead? [Yes/No] <yes>:" )) (if (or (not ans)(= ans "Yes")) (command "_.insert" "the 7.5 block...") ) ) ((= a 7.5) (command "_.insert" "the 7.5 block...") ) ((and (<= 10.0 a 15.0) (/= a 12.5)) (prompt (strcat "\nYour specifide size of " (rtos a) "mm is not available, " )) (initget "Yes No") (setq ans (getkword "would you like to use 12.5 instead? [Yes/No] <yes>:" )) (if (or (not ans)(= ans "Yes")) (command "_.insert" "the 12.5 block...") ) ) ((= a 12.5) (command "_.insert" "the 12.5 block...") ) );; cond );; if (princ) )
HTH
Henrique
I would think, with all the size possibilities you have, that it could be cumbersome to spell out all the (cond)-function conditions for each range between available sizes. Consider making a list of available sizes, and after getting the number from the User,
(if (member a YourSizeList); i.e. it's an available size
(... then -- Insert the appropriate Block ...); i.e. no need to step through lots of possible conditions
(... else -- offer adjacent sizes or closest size ...); see below
); if
I haven't quite figured it out yet, but there's got to be a comparatively simple way to find what are the adjacent available sizes on either side of a User's unavailable size, and offer a choice between them, or just the closest one if the User's size isn't halfway between two of them. If that sounds like a good approach, I'll think about how it might be done, with some kind of incrementing through the list.
@Shneuph wrote:
(and (> a 100.0) (<= a 110)) (prompt "\nNumber is between 100 and 110") );cond2 ....
I'm not sure how your actual size options relate to your sample numbers, but if both 100 and 110 are available sizes, then I assume you don't want that = sign in there -- if they enter 110, that isn't a number between available sizes as that test would claim. If that's the case, I would use:
(< 100 a 110)
for the condition's test expression.
I would suggest the following example:
(defun c:selsize ( / ans lst tmp ) ;; List of available sizes (setq lst '( 10 20 30 40 50 60 70 80 90 100 ) ) ;; Sort list in ascending order (setq lst (vl-sort lst '<)) ;; Is there a default? Is it in the list? (if (not (and selsize:size (member selsize:size lst))) (setq selsize:size (car lst)) ;; If not, use the first item ) (while ;; While the following is true (progn ;; Use the result from the following evaluated expressions (initget 6) ;; Disallow zero & negatives ;; Prompt the user for a size, indicating the default: (setq ans (getreal (strcat "\nSpecify size <" (itoa selsize:size) ">: "))) (cond ( (null ans) ;; User pressed Enter (setq ans selsize:size) ;; Set size to default nil ;; Exit loop ) ( (setq tmp (car (member ans lst))) ;; User has specified a valid size (setq selsize:size tmp ;; Set default to selected size ans tmp ;; Set the variable to the selected size ) nil ;; Exit loop ) ( (progn ;; Use the result from the following evaluated expressions (initget "Yes No") ;; Initialise the keywords ;; Prompt the user whether to use the nearest size (/= "No" (getkword (strcat "\nYour specified size of " (rtos ans 2) "mm is not available, the closest measurement is " ;; Sort the sizes by their numerical distance from the specified size, choose the closest (itoa (setq tmp (nth (car (vl-sort-i (mapcar '(lambda ( x ) (abs (- x ans))) lst) '<)) lst))) "mm\nWould you like to use this instead? [Yes/No] <Yes>: " ) ) ) ) (setq selsize:size tmp ;; Set the default to the selected size ans tmp ;; Set the variable to the selected size ) nil ;; Exit loop ) ( t ) ;; 'No' selected, stay in loop ) ) ) (princ (strcat "\nYou have selected the size: " (itoa ans))) (princ) ;; Suppress the return of the last evaluated expression )
