I need to be able to update the titleblocks for SELECTED layouts only - similar to "publishing" selected tabs. I'm using Lisp.
I'd rather not make a dialog box from the "layoutlist" - it would be easier to select the tabs, then push a button.
Thanks.....
To my knowledge, this is not possible in LISP.
The only way I am aware of to retrieve this information is to use the getTabSelected() function of ObjectArx.
FWIW -
I too know of no way of doing this from LISP natively, however, the .NET API exposes the bool Layout.TabSelected Property, which could be utilized to extend LISP via custom LispFunction Method.
As a quick example, consider this pseudo-named, custom LayoutListSelected function:
Attached to this post is an Autoloader .bundle which supports 2012-2014 natively, but the ./Contents/Windows/2010/ assembly can be NETLOADed into 2010 & 2011 as well, as it has been compiled to .NET 3.5 framework (for those still using pre-Autoloader 2010 Database versions)... Simply download, unblock, and unzip to ..\ApplicationPlugins\, and start AutoCAD.
[Edit] - Autodesk forums would not allow me to upload the attached Autoloader .bundle as a .ZIP, so I've added a .TXT file extension, which seems to have worked... Simply remove this prior to unzipping.
... And for those, like me, that would prefer to compile themselves, here's the source code (C#):
using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using System.Collections.Generic; [assembly: CommandClass(typeof(BlackBox.AutoCAD.LayoutListSelected.Commands))] namespace BlackBox.AutoCAD.LayoutListSelected { class Commands { [LispFunction("LayoutListSelected")] public ResultBuffer LayoutListSelected(ResultBuffer args) { if (args != null) throw new TooManyArgsException(); Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; //Editor ed = doc.Editor; //LayoutManager layoutMgr = LayoutManager.Current; List<string> layouts = new List<string>(); ResultBuffer res = new ResultBuffer(); using (Transaction tr = db.TransactionManager.StartTransaction()) { DBDictionary layoutDic = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead, false); foreach (DBDictionaryEntry entry in layoutDic) { Layout layout = (Layout)tr.GetObject(entry.Value, OpenMode.ForRead); string layoutName = layout.LayoutName; if (layout.TabSelected) layouts.Add(layoutName); } tr.Commit(); } layouts.Remove("Model"); if (0 < layouts.Count) { layouts.Sort(); foreach (string layoutName in layouts) { res.Add(new TypedValue(5005, layoutName)); } return res; } else return null; } } // Special thanks to Gile for his LispException classes: class LispException : System.Exception { public LispException(string msg) : base(msg) { } } class TooFewArgsException : LispException { public TooFewArgsException() : base("too few arguments") { } } class TooManyArgsException : LispException { public TooManyArgsException() : base("too many arguments") { } } class ArgumentTypeException : LispException { public ArgumentTypeException(string s, TypedValue tv) : base(string.Format( "invalid argument type: {0}: {1}", s, tv.TypeCode == (int)LispDataType.Nil ? "nil" : tv.Value)) { } } }
"How we think determines what we do, and what we do determines what we get."
@JoistDetailer wrote:
That looks like it will work. I appreciate your response and effort!
However, you lost me when you said to "download, unblock, and unzip to .." - what do you mean by "unblock"?? Please pardon my ignorance...I'm not familiar with the Autoloader or dotNet.
No worries; this was just a quick example.
If you're using 2012 or newer:
if you're using 2011 or 2010:
Now, if you're using 2009 or older, let me know... I'll have to see if this API feature (the TabSelected Property) was exposed to .NET 3.0 Framework, etc. and attempt to provide you an additional asembly, etc.
It sounds like a lot if you're not already familiar, but this is really quite simple once you've done it... Hope this makes (more?) sense now.
Cheers
Did you ever get a chance to test this?
No, I didn't.....I just found out that you had replied....I'll try it out in the next few weeks. thanks!
"I'll try it out in the next few weeks"
Lol
@ BB
Sorry buddy, I can test it for you if you're needing to see if it works
It will probably be sooner than that, but I'm jammed with "production" work that I need to do first. I'm kind of a "part time" programmer. I make tools to help myself (and others, once it's debugged) when time permits.
thanks!!
@JoistDetailer wrote:It will probably be sooner than that, but I'm jammed with "production" work that I need to do first. I'm kind of a "part time" programmer. I make tools to help myself (and others, once it's debugged) when time permits.
thanks!!
No worries; I'm a production guy too.
It works fine here (as I tried to demonstrate above), but just wanted to follow up and see if it does what you're after. No rush.
Cheers
Hi, this looks great, but i could not make the function work in acad 2016 in Win 8.1.
I copied the bundle folder "BlackBox Layout List Selected.bundle" to both:
c:\Program Files\Autodesk\ApplicationPlugins\
c:\Program Files (x86)\Autodesk\ApplicationPlugins\
Is the content from ApplicationPlugins folders loaded automatically upon Autocad startup in 2016?
I finally got around to checking this out and I can't get it to work.
I put the file into the Application Add-ins folder and started AutoCad 2014, but when I enter the command name, it says that the command name is unknown.
AutoCad 2014 and Windows 7 Professional.
Thanks!!
