I there any way to set the dimension break size in autolisp
@cadking2k5 wrote:I there any way to set the dimension break size in autolisp
If I understand what you're asking:
(setvar 'dimgap YourValue)
or maybe you mean the 'dimexo System Variable instead -- read about those two to decide.
@yyxuxyy wrote:
i think this is what he means.
Probably, but since they want to set it in AutoLisp, it's necessary to know the name of the System Variable that stores it. Help isn't crystal clear about it, but DIMGAP is described as saving "the distance around the dimension text when the dimension line breaks to accommodate dimension text," so I assume that's the one.
I found out that i asked this same question and solved it about 10 years ago under my old user name...
The code there retrieves it... but does not set it, but shouldn't take much to alter it to change the value.
https://forums.autodesk.com/t5/autocad-forum/dimbreak-gap-size/td-p/1917127
