• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    New Member
    How to properly link to DCL?
    391 Views, 5 Replies
    05-27-2012 02:04 PM
    Hi...I'm a total beginner with AutoLISP and I have to get an my first project done. The problem I'm having is that even if I try using the most basic code, taken from this tutorial:
    http://www.afralisp.net/dialog-control-language/tutorials/dialog-boxes-and-autolisp-part-1.php
    I still get an error as if the dcl file didn't exist. Both the lisp and the DCL files are both set in the same folder, together, no sub-folders or anything like that.
    Please take a look and tell me what I'm doing wrong...I'm...really stumped and can't figure it out.
    Here's my code:
    - DCL:
    samp1 : dialog {
        label = "Structural Holes";
        ok_cancel;
    - LISP
    (defun C:samp1()
      (setq dcl_id (load_dialog "C:\Users\Eugen Iancu\Desktop\learnLisp\samp1.DCL"))
      (if (not (new_dialog "C:\Users\Eugen Iancu\Desktop\learnLisp\samp1.DCL" dcl_id))
        (COMMAND "ZOOM") ;;THIS IS WERE MY FUNCTION GETS STUCK. I ADDED THIS SO I COULD CLEARLY SEE           WHAT GOES WRONG
      (action_tile
           "cancel"
           "(done_dialog)(setq userclick nil)"
      (action_tile
        "accept"
        "(done_dialog)(setq userclick T))"
      (start_dialog)
      (princ)
    (princ)
    Please use plain text.
    Valued Mentor
    _Tharwat
    Re: How to properly link to DCL?
    05-27-2012 09:43 PM in reply to: eug3n91
    First save the DCL codes to your Autocad Support folder e.g.
    C:\Program Files\AutoCAD 20**\Support
    and after that load the lisp file to your current opened drawing and run the code .
    Good luck .
    Valued Mentor
    05-31-2012 03:45 AM in reply to: eug3n91
    "\" is treated as an escape character, when feeding a string to a lisp function.
    You need to use "\\" in file path strings etc.
    Replace
    with
    (setq dcl_id (load_dialog "C:\\Users\\Eugen Iancu\\Desktop\\learnLisp\\samp1.DCL"))
    The first argument of the new_dialog function is the name of a dialog defined in the DCL file, not the DCL file name itself.
    Replace
    with
    (if (not (new_dialog "samp1" dcl_id))
    Ian
    *Pro
    scot-65
    05-31-2012 03:41 PM in reply to: eug3n91
    Whenever I write code that includes a dialog box, I first create a folder,
    then add a "test.DWG", and of course place the LSP and DCL files in there
    for a total of three files in this folder.
    By opening this test.DWG file, you automatically have a "current directory" path
    to where you do not need to declare a "Hard-Path" for the DCL file, as the DCL
    is located in the current directory.
    Whenever you make changes to the LSP file, you have to reload it:
    (load "samp1"). Again, the current directory makes it easy to (re)load.
    Do yourself a favor and always include (unload_dialog dcl_id) in your LSP file
    just after the (start_dialog) so that too can be reloaded (more of a memory
    manager than a reload).
    Another trick I use is to temporarily cancel out the first and last lines, which saves
    me a step to start the program without having to enter the command.
    When the program is finished to my satisfaction, the semi-colons are removed.
    ;(defun c:TEST ()
    :smileywink:
    Good Luck!
    05-31-2012 11:00 PM in reply to: eug3n91
    Another option is to incorporate the DCL onto your lisp rouitne
    (Defun c:showLayerDemo  (/ CDiaStr a laylst)
    (setq laylst nil)
    (defun CDiaStr  (/ fnSTR ListBoxDia)
                (setq StrDiaFnme (vl-filename-mktemp "tmp.DCL"))
                (setq fnSTR (open StrDiaFnme "a"))
                (write-line
                      "dcl_settings : default_dcl_settings { audit_level = 3; }
      ShowLayers : dialog
      { label = \"\"; key= \"Taytol\";
      : list_box { key = \"StrListS\"; multiple_select =
      true; width = 20; height = 20; } spacer ;
      ok_cancel;
      }"              fnSTR)
                (close fnSTR)
                T
    (defun ListBoxDia (DiaName DiaKey Title Lst)
         (setq StrDIA (load_dialog StrDiaFnme))
        (if (not (new_dialog DiaName StrDIA))
              (exit)
        (start_list DiaKey)
        (mapcar 'add_list Lst)
        (end_list)
        (set_tile "Taytol" Title)
        (action_tile
              DiaKey
              (vl-prin1-to-string
                    (quote (set (setq dd (read DiaKey))
                                (get_tile $key)))))
        (action_tile "accept" "(done_dialog 1)")
        (action_tile "cancel" "(done_dialog 0)")
        (start_dialog)
        (unload_dialog StrDIA)
     (while (setq a (tblnext "LAYER" (null a)))
                 (setq laylst (cons (cdr (assoc 2 a)) laylst)))
           (CDiaStr)
           (ListBoxDia
                 "ShowLayers"
                 "StrListS"
                 "Select String to Follow"
                 (acad_strlsort laylst))
           (vl-file-delete StrDiaFnme)
    (princ)
    HTH
    DCL to LISP Generator..
    06-01-2012 11:11 PM in reply to: pbejse
    Embedding  the file.DCL into LISP source automatically...
    [code]
    t025 (strcat t025  "\noptionh :dialog {\n label = \"Style H Option\";\n:row {\n : boxed_column { \n label = \"Style H Options\";\n : boxed_radio_row {\n key = \"Holes\";\n label = \"How Many Holes Per Side?\";\n : radio_button {key = \"Two\"; ");;
    t025 (strcat t025  "label = \"2 Holes Per Side\";}\n : radio_button {key = \"Three\"; label = \"3 Holes Per Side\";}\n }\n : boxed_radio_row {\n key = \"Inline\";\n label = \"Are Holes Inline?\";\n : radio_button {key = \"Y\"; label = \"Yes\";}\n : ");;
    t025 (strcat t025  "radio_button {key = \"N\"; label = \"No\";}\n }\n : boxed_radio_row {\n key = \"Chamfer\";\n label = \"Is Inside Hole Chamfered?\";\n : radio_button {key = \"Yes\"; label = \"Yes\";}\n : radio_button {key = \"No\"; label = \"No\";}\n");;
    t025 (strcat t025  " }\n : boxed_radio_row {\n key = \"InsOut\";\n label = \"Is Distance from Pole Shaft to Inside or Outside Hole?\";\n : radio_button {key = \"Inside\"; label = \"Inside Hole\";}\n : radio_button {key = \"Outside\"; label = \"Outside Hole\";}\n");;
    t025 (strcat t025  " }\n }\n\n : boxed_column { \n label = \"Vang Dimensions and Table Information\";\n : boxed_radio_column {\n key = \"option\";\n label = \"Select Option\" ;\n : radio_button {key = \"1\"; label = \"Double Sided - Flats 1 && 7\" ");;
    t025 (strcat t025  ";}\n : radio_button {key = \"2\"; label = \"Double Sided - Flats 4 && 10\" ;}\n : radio_button {key = \"3\"; label = \"Double Sided - Positive Angle\" ;}\n : radio_button {key = \"4\"; label = \"Double Sided - Negative Angle\";}\n");;
    t025 (strcat t025  " : radio_button {key = \"5\"; label = \"Single Sided - Flat 1\" ;}\n : radio_button {key = \"6\"; label = \"Single Sided - Flat 4\" ;}\n : radio_button {key = \"7\"; label = \"Single Sided - Flat 7\" ;}\n : radio_button ");;
    t025 (strcat t025  "{key = \"8\"; label = \"Single Sided - Flat 10\" ;}\n : radio_button {key = \"9\"; label = \"Single Sided - Positive Angle - Opposite Side\" ;}\n : radio_button {key = \"10\"; label = \"Single Sided - Positive Angle - Near Side\" ");;
    t025 (strcat t025  ";}\n : radio_button {key = \"11\"; label = \"Single Sided - Negative Angle - Opposite Side\" ;}\n : radio_button {key = \"12\"; label = \"Single Sided - Negative Angle - Near Side\" ;}\n }\n }\n\n \n : boxed_column { \n key = ");;
    t025 (strcat t025  "\"dimensions\";\n label = \"Dimensions of Vang\";\n : edit_box {\n label = \"Width of Vang (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"width\";\n }\n : edit_box ");;
    t025 (strcat t025  "{\n label = \"Hole to Shaft Dimension (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"hole2shaft\";\n }\n : edit_box {\n label = \"Weld Size:\";\n edit_limit = ");;
    t025 (strcat t025  "4;\n edit_width = 4;\n fixed_height = true;\n is_enabled = true;\n key = \"weldsz\";\n }\n : edit_box {\n label = \"Hole Diameter (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = ");;
    t025 (strcat t025  "true;\n key = \"holedia\";\n }\n : edit_box {\n label = \"Radius (Include Inch Mark):\";\n edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"rad\";\n }\n : edit_box {\n label = \"Vertical Hole Spacing (Include Inch Mark):\";\n");;
    t025 (strcat t025  " edit_limit = 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"VERT_HSPACING\";\n }\n : edit_box {\n label = \"Horizontal Hole Spacing (Include Inch mark):\";\n edit_limit ");;
    t025 (strcat t025  "= 10;\n edit_width = 10;\n fixed_height = true;\n is_enabled = true;\n key = \"HORZ_HSPACING\";\n }\n }\n\n : boxed_radio_column { \n key = \"table\";\n label = \"Number of Lines in Table\" ;\n : radio_button {key = \"N1\"; ");;
    t025 (strcat t025  "label = \"1 Line in Table\" ;}\n : radio_button {key = \"N2\"; label = \"2 Lines in Table\" ;}\n : radio_button {key = \"N3\"; label = \"3 Lines in Table\" ;}\n : radio_button {key = \"N4\"; label = \"4 Lines in Table\" ;}\n : radio_button ");;
    t025 (strcat t025  "{key = \"N5\"; label = \"5 Lines in Table\" ;}\n }\n }\n\n}\n\n:row {alignment=centered; fixed_width=true;\n ok_cancel;\n}\n}\n\n"))
    ;(str_princ (list ))
    [/code]
    HERE is Original DCL :mantongue: :smileywink::smileyembarrassed:
    [code]
    optionh :dialog {
       label = "Style H Option";
    :row {
      : boxed_column {         //COLUMN 1
      label = "Style H Options";
      : boxed_radio_row {
        key = "Holes";
        label = "How Many Holes Per Side?";
        : radio_button {key = "Two"; label = "2 Holes Per Side";}
        : radio_button {key = "Three"; label = "3 Holes Per Side";}
      : boxed_radio_row {
        key = "Inline";
        label = "Are Holes Inline?";
        : radio_button {key = "Y"; label = "Yes";}
        : radio_button {key = "N"; label = "No";}
      : boxed_radio_row {
        key = "Chamfer";
        label = "Is Inside Hole Chamfered?";
        : radio_button {key = "Yes"; label = "Yes";}
        : radio_button {key = "No"; label = "No";}
      : boxed_radio_row {
        key = "InsOut";
        label = "Is Distance from Pole Shaft to Inside or Outside Hole?";
        : radio_button {key = "Inside"; label = "Inside Hole";}
        : radio_button {key = "Outside"; label = "Outside Hole";}
     }//COLUMN 1
      : boxed_column {          //COLUMN 2
      label = "Vang Dimensions and Table Information";
        key = "option";
        label = "Select Option" ;
        : radio_button {key = "1"; label = "Double Sided - Flats 1 && 7" ;}
        : radio_button {key = "2"; label = "Double Sided - Flats 4 && 10" ;}
        : radio_button {key = "3"; label = "Double Sided - Positive Angle" ;}
        : radio_button {key = "4"; label = "Double Sided - Negative Angle";}
        : radio_button {key = "5"; label = "Single Sided - Flat 1" ;}
        : radio_button {key = "6"; label = "Single Sided - Flat 4" ;}
        : radio_button {key = "7"; label = "Single Sided - Flat 7" ;}
        : radio_button {key = "8"; label = "Single Sided - Flat 10" ;}
        : radio_button {key = "9"; label = "Single Sided - Positive Angle - Opposite Side" ;}
        : radio_button {key = "10"; label = "Single Sided - Positive Angle - Near Side" ;}
        : radio_button {key = "11"; label = "Single Sided - Negative Angle - Opposite Side" ;}
        : radio_button {key = "12"; label = "Single Sided - Negative Angle - Near Side" ;}
     }//COLUMN 2
      : boxed_column {                   //COLUMN 3
        key = "dimensions";
        label = "Dimensions of Vang";
        : edit_box {
          label = "Width of Vang (Include Inch Mark):";
          edit_limit = 10;
          edit_width = 10;
          is_enabled = true;
          key = "width";
        : edit_box {
          label = "Hole to Shaft Dimension (Include Inch Mark):";
          edit_limit = 10;
          edit_width = 10;
          is_enabled = true;
          key = "hole2shaft";
        : edit_box {
          label = "Weld Size:";
          edit_limit = 4;
          edit_width = 4;
          is_enabled = true;
          key = "weldsz";
        : edit_box {
          label = "Hole Diameter (Include Inch Mark):";
          edit_limit = 10;
          edit_width = 10;
          is_enabled = true;
          key = "holedia";
        : edit_box {
          label = "Radius (Include Inch Mark):";
          edit_limit = 10;
          edit_width = 10;
          is_enabled = true;
          key = "rad";
        : edit_box {
          label = "Vertical Hole Spacing (Include Inch Mark):";
          edit_limit = 10;
          edit_width = 10;
          is_enabled = true;
          key = "VERT_HSPACING";
        : edit_box {
          label = "Horizontal Hole Spacing (Include Inch mark):";
          edit_limit = 10;
          edit_width = 10;
          is_enabled = true;
          key = "HORZ_HSPACING";
         }//COLUMN 3
       : boxed_radio_column {                   //COLUMN 4
         key = "table";
         label = "Number of Lines in Table" ;
         : radio_button {key = "N1"; label = "1 Line in Table" ;}
         : radio_button {key = "N2"; label = "2 Lines in Table" ;}
         : radio_button {key = "N3"; label = "3 Lines in Table" ;}
         : radio_button {key = "N4"; label = "4 Lines in Table" ;}
         : radio_button {key = "N5"; label = "5 Lines in Table" ;}
       }//COLUMN 4
    }//ROW
         ok_cancel;
    }//DIALOG
    [/code]
