Sorry.... I seem to have left an unwanted space before the final zeros in
the shape definitions (see fixed ones below).
As penance, I offer a slightly shorter way of defining the filled box, using
horizontal instead of vertical infill lines:
*135,13,BOXFILLED
040,02C,048,044,040, 03C, 048,024, 040, 01C,048,0
And a slightly DENSER way using diagonal fill in the same size box:
*135,21,BOXFILLED
024,040,04C,048,034,012,010,02A,01C,032,010,04A,010,032,01C,02A,010,012,014,048,0
[Again, I haven't tested them, so further penance may be in order. Watch
for word wrap.]
If those aren't dense enough, you could make a SIX-unit (or EIGHT- or
TEN-unit, or whatever) box with a longer shape definition, and reduce the
scale part in the linetype definition accordingly.
Kent Cooper
"Kent Cooper" wrote...
If three internal lines would fill it densely enough for you, try something
like:
*132,14,BOX
024,040,04C,048,044,010, 04C, 010,044, 010, 04C,038,024,0 <<--[ removed
space before final zero]
[That has a little overlap, but it's shorter than adding pen-up stuff to
avoid that.]
And since that's a FOUR-unit square, adjust the linetype definition to use
it at half the size:
*FENCELINE2,Fenceline
square ----[|||]-----[|||]----[|||]-----[|||]----[|||]---
A,.25,-.1,[BOX,ltypeshp.shx,x=-.1,s=.05],-.1,1
Or, if you want to keep the open-square one available, add another shape to
LTYPESHP.SHP, and linetype to ACAD.LIN, something like:
*135,14,BOXFILLED
[Use the next available unused shape number, if 135 is already used.]
*FENCELINE3,Fenceline filled
A,.25,-.1,[BOXFILLED,ltypeshp.shx,x=-.1,s=.05],-.1,1
