I am looking for a lisp code to get full name of autocad.
for example my autocad is "Auto CAD 2013 SP2"
I know (getvar 'acadver) can give version of AutoCAD but how can I know about service packs? (SP1 or SP2 ...)
I think the easiest way is looking at registery:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B001\Service Packs\AutoCAD 2013\PatchTitle
its value is exactly what I want: "Auto CAD 2013 SP2"
So, I prepared this code to get this value:
(defun c:GetAcadVer ( / HLM key reg Ver PN ) (setq HLM "HKEY_LOCAL_MACHINE\\" key (vlax-product-key);=>"Software\\Autodesk\\AutoCAD\\R19.0\\ACAD-B001:409" reg (substr key 1 (vl-string-search ":" key));=>"Software\\Autodesk\\AutoCAD\\R19.0\\ACAD-B001" Ver (car (vl-registry-descendents (strcat HLM reg "\\Service Packs")));=>"AutoCAD 2013" PN (vl-registry-read (strcat HLM reg "\\Service Packs\\" Ver) "PatchTitle");=>"AutoCAD 2013 SP2" ) )
RESULT:===> "Auto CAD 2013 SP2"
But I don't know is there any other solution to find out which service pack is installed?
Does anybody has a idea?
Abbas Aqdam
Solved by aqdam1978. Go to Solution.
Not sure if this will do it for you but...
(getvar "_vernum") on my machine returns
"I.108.0.0 (UNICODE)"
Which if I look it up I know that I.108.0.0 is 2014 service pack 1 while I.18.0.0 is SP0.
G.xxx is 2013, F.xxx is 2012, and so on. Typically if the first set of numbers is 3 digits the first digit indicates the number of the service pack. If the first set is two digits it indicates SP0. the _vernum is a bit easier to get at than all the registry stuff.
Hi p_mcknight,
Thank you for your help.
YES, _VERNUM, Returns a build number for AutoCAD. Itallows you to tell what service pack is installed for AutoCAD.
(see attached PDF file please)
AutoCAD version Value returned by _VERNUM ---------------------------------------------------------------------------- AutoCAD 2000 (shipping) T.0.98 / T.1.07 AutoCAD 2000 (+ Service Pack 1) T.1.08 AutoCAD 2000 (+ Service Pack 2) T.1.09 AutoCAD 2000i (shipping) U.0.90 AutoCAD 2000i (+ Service Pack 1) U.1.20 AutoCAD 2000i (+ Service Pack 2) U.1.81 AutoCAD 2002 (shipping) K.0.30 AutoCAD 2002 (+ Service Pack 1) K.0.44 AutoCAD 2004 (shipping) V.0.86 AutoCAD 2004 (+ Service Pack 1a) V.1.22 AutoCAD 2005 (shipping) N.0.63 AutoCAD 2005 (+ Service Pack 1) N.0.84 AutoCAD 2006 (shipping) Z.54.10 AutoCAD 2006 (+ Service Pack 1) Z.77.0 AutoCAD 2007 (shipping) A.54.0 AutoCAD 2007 (+ Service Pack 1) A.116.0 AutoCAD 2008 (shipping) B.51.0 (UNICODE) AutoCAD 2008 (+ Service Pack 1) B.219.0 (UNICODE) AutoCAD 2009 (shipping) C.56.0 (UNICODE) AutoCAD 2009 (+ Service Pack 1) C.111.0 (UNICODE) AutoCAD 2009 (+ Service Pack 1 (subscription)) C.112.0 (UNICODE) AutoCAD 2009 (+ Service Pack 2) C.608.0 (UNICODE) AutoCAD 2009 (+ Service Pack 3) C.711.0 (UNICODE) AutoCAD 2010 (shipping) D.55.0 (UNICODE) AutoCAD 2010 (+ Service Pack 1) D.215.0 (UNICODE) AutoCAD 2011 (shipping) E.49.0 (UNICODE) AutoCAD 2011 (+ Update 1.1) Update 1 was replaced. E.115.0.0 (UNICODE) AutoCAD 2011 (+ Update 2) E.209.0.0 (UNICODE) AutoCAD 2012 (shipping) F.51.0.0 (UNICODE) AutoCAD 2012 (+ Service Pack 1) F.107.0.0 (UNICODE) AutoCAD 2012 (+ Service Pack 2) F.205.0.0 (UNICODE) AutoCAD 2013 G.55.0.0 (UNICODE) AutoCAD 2013 (+ Service Pack 1) G.112.0.0 (UNICODE) AutoCAD 2013 (+ Service Pack 1.1) G.114.0.0 (UNICODE) Other values: R.1.601 > R13c4 P.0.33 > R14.01 T.1.33 > Mechanical Desktop 4 T.1.35 > Mechanical Desktop 4 SP3 T.1.07 > Architectural Desktop 2 U.0.35 > AutoCAD 2000i beta U.1.00 > Mechanical Desktop 5 AutoCAD 2000i based applications U.0.90 > AutoCAD 2000i initial release U.0.91 > LT 2000i initial release U.1.20 > SP1 on 2000i based product U.1.81 > SP2 on 2000i based product AutoCAD 2000 based applications: T.0.98 > AutoCAD 2000 initial T.1.00 T.1.02 > GIS T.1.03 T.1.05 > ADT2 T.1.07 > LDDT2 T.1.08 > AutoCAD 2000 SP1 T.1.09 > AutoCAD 2000 SP2 T.1.33 > MDT4 T.1.35
But your algorithm is not correct! look at this samples please:
AUTOCAD 2013 SP0 VERNUM=G.55.0.0 SP1 VERNUM=G.112.0.0 SP1.1 VERNUM=G.114.0.0 SP2 VERNUM=G.204.0.0 AutoCAD Architecture 2013 SP0 VERNUM=G.112.0.0 SP1 VERNUM=G.114.0.0 SP2 VERNUM=G.204.0.0 AutoCAD 2009 SP0 VERNUM=C.56.0 SP1 VERNUM=C.111.0 SP1+SAP VERNUM=C.112.0 SP2 VERNUM=C.608.0 SP3 VERNUM=C.711.0
so, the fisrt digit does not present service pack number!
But, Thank you for your help.
Abbas Aqdam
(defun c:GetAcadVer ( / V N ) (setq N (vla-get-caption (vlax-get-acad-object)) V (getvar '_vernum) ) (cond ((= V "B.51.0 (UNICODE)") "AutoCAD 2008") ((= V "B.219.0 (UNICODE)") "AutoCAD 2008 SP1") ((= V "C.56.0 (UNICODE)") "AutoCAD 2009") ((= V "C.111.0 (UNICODE)") "AutoCAD 2009 SP1") ((= V "C.112.0 (UNICODE)") "AutoCAD 2009 SP1ss") ((= V "C.608.0 (UNICODE)") "AutoCAD 2009 SP2") ((= V "C.711.0 (UNICODE)") "AutoCAD 2009 SP3") ((= V "D.55.0 (UNICODE)") "AutoCAD 2010") ((= V "D.215.0 (UNICODE)") "AutoCAD 2010 SP1") ((= V "E.49.0 (UNICODE)") "AutoCAD 2011") ((= V "E.115.0.0 (UNICODE)") "AutoCAD 2011 SP1.1") ((= V "E.209.0.0 (UNICODE)") "AutoCAD 2011 SP2") ((= V "F.51.0.0 (UNICODE)") "AutoCAD 2012") ((= V "F.107.0.0 (UNICODE)") "AutoCAD 2012 SP1") ((= V "F.205.0.0 (UNICODE)") "AutoCAD 2012 SP2") ((= V "G.55.0.0 (UNICODE)") "AutoCAD 2013") ((= V "G.112.0.0 (UNICODE)") "AutoCAD 2013 SP1") ((= V "G.114.0.0 (UNICODE)") "AutoCAD 2013 SP1.1") ((= V "G.204.0.0 (UNICODE)") "AutoCAD 2013 SP2") ((= V "I.18.0.0 (UNICODE)") "AutoCAD 2014") ((= V "I.108.0.0 (UNICODE)") "AutoCAD 2014 SP1") ((= V "J.18.0.0 (UNICODE)") "AutoCAD 2015");<<<??? (t (strcat N ", Build number is: " V )) );cond )
(defun c:GetAcadVer ( / V N ) (setq N (vla-get-caption (vlax-get-acad-object)) V (getvar '_vernum) ) (cond ((= V "A.54.0") "AutoCAD 2007") ((= V "A.116.0") "AutoCAD 2007 SP1") ((= V "B.51.0 (UNICODE)") "AutoCAD 2008") ((= V "B.219.0 (UNICODE)") "AutoCAD 2008 SP1") ((= V "C.56.0 (UNICODE)") "AutoCAD 2009") ((= V "C.111.0 (UNICODE)") "AutoCAD 2009 SP1") ((= V "C.112.0 (UNICODE)") "AutoCAD 2009 SP1.1") ((= V "C.608.0 (UNICODE)") "AutoCAD 2009 SP2") ((= V "C.711.0 (UNICODE)") "AutoCAD 2009 SP3") ((= V "D.55.0 (UNICODE)") "AutoCAD 2010") ((= V "D.215.0 (UNICODE)") "AutoCAD 2010 SP1") ((= V "E.49.0 (UNICODE)") "AutoCAD 2011") ((= V "E.115.0.0 (UNICODE)") "AutoCAD 2011 SP1.1") ((= V "E.209.0.0 (UNICODE)") "AutoCAD 2011 SP2") ((= V "F.51.0.0 (UNICODE)") "AutoCAD 2012") ((= V "F.107.0.0 (UNICODE)") "AutoCAD 2012 SP1") ((= V "G.55.0.0 (UNICODE)") "AutoCAD 2013") ((= V "G.112.0.0 (UNICODE)") "AutoCAD 2013 SP1") ((= V "G.114.0.0 (UNICODE)") "AutoCAD 2013 SP1.1") ((= V "G.204.0.0 (UNICODE)") "AutoCAD 2013 SP2") ((= V "I.18.0.100 (UNICODE)") "AutoCAD 2014") ((= V "I.108.0.0 (UNICODE)") "AutoCAD 2014 SP1") ((= V "J.51.0.0 (UNICODE)") "AutoCAD 2015") ((= V "J.104.0.0 (UNICODE)") "AutoCAD 2015 SP1") ((= V "J.210.0.0 (UNICODE)") "AutoCAD 2015 SP2") ((= V "M.49.0.0 (UNICODE)") "AutoCAD 2016") ((= V "M.107.0.0 (UNICODE)") "AutoCAD 2016 SP1") ((= V "M.107.0.12 (UNICODE)") "AutoCAD 2016 SP1 HF3") ((= V "M.107.0.19 (UNICODE)") "AutoCAD 2016 SP1 HF4") ((= V "N.52.0.0 (UNICODE)") "AutoCAD 2017") ((= V "N.52.0.1 (UNICODE)") "AutoCAD 2017 HF1") ((= V "N.52.0.7 (UNICODE)") "AutoCAD 2017 HF2") ((= V "N.104.0.0 (UNICODE)") "AutoCAD 2017 SP1") ((= V "N.212.0.0 (UNICODE)") "AutoCAD 2017.1") ((= V "N.301.0.0 (UNICODE)") "AutoCAD 2017.1.1") ((= V "O.61.0.0 (UNICODE)") "AutoCAD 2018.0.1") ((= V "O.72.0.0 (UNICODE)") "AutoCAD 2018.0.2") ((= V "O.107.0.0 (UNICODE)") "AutoCAD 2018.1") ((= V "O.154.0.0 (UNICODE)") "AutoCAD 2018.1.1") ((= V "O.161.0.0 (UNICODE)") "AutoCAD 2018.1.2") ((= V "P.46.0.0 (UNICODE)") "AutoCAD 2019") (t (strcat N ", Build number is: " V )) );cond )
