Visual LISP, AutoLISP and General Customization
How to execute and exit VLISP in lisp code?
4 REPLIES 4
aqdam1978
1335 Views, 4 Replies
I need to run VLISP / (_VLIDE) in my lisp code.
how can I run _VLIDE inside of my lisp code and also how can close VLISP by lisp code?
[VLISP=_VLIDE=Visual Lisp Editor]
4 REPLIES 4
mkweaver
in reply to: aqdam1978
(C:vlide) will start the editor but I don't know of any way to close the editor using lisp.
Mike Weaver
ales.stanek
if you want to run vlide in code and it isn't last operation. Use syntax (C:vlide T). The command start vlide and get back control to original program. I use it for automatic build fas files.
Ales Stanek
aqdam1978
in reply to: ales.stanek
YES, exactly I want to uses in my code that I prepare to BATCH FAS MAKER!!!
my code is:
(defun c:FAS_Maker (/ path files itm des)
	(defun ReplaceStr (NewStr Patt Str / pos)
		(setq pos 0)
		(While (setq pos (vl-string-search patt str pos))
			(setq Str (vl-string-subst NewStr patt Str pos))
			(setq pos (+ pos (strlen NewStr)))
	str
	(setq path "C:\\LISP\\")
	(setq files (vl-directory-files path "*.LSP" 1))
	(if (> (length files) 0)
		(progn
			(setq des (open (strcat path "t.scr") "w" ))
			 (foreach itm files
				(write-line (strcat "(vlisp-compile 'st \"" (ReplaceStr "\\\\" "\\" path) itm "\")") des)
			 );;foreach
			(write-line "(alert \"All files compiled...\")" des)
			(close des)
			(C:VLIDE T)
			(command "script" (strcat path "t.scr"))
			;;(close "VLIDE");;
			(princ)
		);;progn
		(alert "Error!:\n\nThere is no any \"*.LSP\" files in \"C:\\LISP\\\" folder!\n\nPlease copy your *.LSP files to this folder and try again!")
	);;if
);;defun
 Just copy your LSP files to C:\LISP\ folder and run the code!
BUT!, I can't close VLISP via lisp code!
does anybody knows that how can I close VLIDE?!
Abbas
ales.stanek
hi,
I use a litle diferent approach.
I create bat file that run autocad with scr file. (The bat file I start manualy but is possible make this as "night build" by windows scheduler or run this bat file by innosetup for example.)
scr file load and run lisp file.
by vl-catch-all-apply i manage proces of creating fas files for each lsp file
and at the end i quit AutoCAD
Ales Stanek
”Boost
