Visual LISP, AutoLISP and General Customization
Distinguished Contributor fk
fk
Message 1 of 5 (156 Views)
How to empty a multiline attribute?
156 Views, 4 Replies
10-19-2012 04:41 AM
Hi.
I have some multiline attributes that contain strings that are longer than 250 characters. Someone that know how to empty the attribute using autolisp?
Thanks in advance.
\Freddy
*Expert Elite*
pbejse
Message 2 of 5 (153 Views)
Re: How to empty a multiline attribute?
10-19-2012 04:58 AM in reply to: fk
fk wrote:
Hi.
Thanks in advance.
\Freddy
Are there other attributes on the block besides the multiline?  or blank all attributes regardless if its multiline or not?
*Expert Elite*
pbejse
Message 3 of 5 (147 Views)
10-19-2012 05:22 AM in reply to: pbejse
(defun c:begone (/ atr)(vl-load-com)
  (while (setq atr (car (nentsel "\nSelect Attribute:" )))
    		(vla-put-textstring (vlax-ename->vla-object atr) "")))
(defun c:begonem (/ atr)(vl-load-com)
    		(if (eq (vla-get-MTextAttribute (setq atr (vlax-ename->vla-object atr))) :vlax-true)
    		(vla-put-textstring atr "")))
(defun c:begoneML (/ ss)(vl-load-com)
  	(if (setq ss (ssget ":L" '((0 . "INSERT")(66 . 1))))
	  	(repeat (sslength ss)
		  (foreach itm (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'Getattributes)
		    	(if (eq (vla-get-MTextAttribute itm) :vlax-true)
			  	(vla-put-textstring itm "")))
		  (ssdel (ssname ss 0) ss)
(defun c:begoner ( / ss)(vl-load-com)
GTG
*Expert Elite*
3wood
Message 4 of 5 (139 Views)
10-19-2012 06:07 AM in reply to: fk
Please try attached routine, select blocks, specify which attribute, then in the dialogue box set "Replace mode" as "New" and "New text" as a space.
fk
Message 5 of 5 (133 Views)
10-19-2012 06:19 AM in reply to: pbejse
This is great! Thanks  a lot "pbejse". You saved my day.
\Freddy
You are not logged in.
Announcements
Need installation help?
Ask the Community
