Visual LISP, AutoLISP and General Customization
How to change the extrusion direction
4 REPLIES 4
3242 Views, 4 Replies
I like to change the Z= propertie form lines and arcs (that are from a exploded solids from
a 3d solid) extrusion direction relative to UCS:
X= 0.0000 Y= 0.0000 Z= -1.0000
Propertie box: Geometry: Normal Z= -1.0000
Explanation in the autocad help:
Reports the X,Y,Z values of the normal direction vector relative to the WCS
This property specifies a vector, not a location in space
The Z-value should be 1
Peter D
4 REPLIES 4
one way...
(DEFUN CHANGEZ()
(SETQ ENT(CAR(ENTSEL"\nPick"))
elst(entget ent)
extr(cdr(assoc 210 elst)) ; get the existing extrusion direction
;modify the z as needed
;just for example I made the z -1 since the line I selected started out with
1
(setq newextr(list (car extr)(cadr extr) -1))
;you would reverse that for your needs or whatever other adjustments you
wanted to do
;rewrite the entity list with new extrusion direction
(setq elst
(subst (cons 210 newextr)
(assoc 210 elst)
Elst
;update database
(entmod elst)
hth
Mark
"petd" wrote in message news:f16e2e1.-1@WebX.maYIadrTaRb...
> Hi,
WCS
> Peter D
or possibly you might want to do...
(setq newextr(list (car extr)(cadr extr) (abs(caddr extr))))
in lieu of the line below
"Mark Propst" wrote in message
news:A3FC2498E496F8883C3922A075A9BD0F@in.WebX.maYIadrTaRb...
> one way...
Mark,
You already helped me a lot, but i still have a little problem with the coördinates, after running the routine the changed entities goes to other coordinates, i tried to resolve the problem with trans the coördinates but this wont help (note: i made the drawing in world coördinates).
Peter D.
Mark, I realize this is an old issue but hopefully you won't mind revisiting it.  Assume a hole located at 2,3 with a direction vector of 0,0,-1.  When I run your suggested program the direction vector is changed to 0,0,1 but in addition, the hole is spun around the y axis 180 degrees and now is located at -2,3.  Any suggestions as to how to keep the hole at the original location?
”Boost
