Currently, I am aware of the plotstamp available in the Plot Dialog box, however, we are looking at ways to imbed this info in the dwg. I currently have the WD_TB with an attribute for FULLFILENAME, an attribute for PLOTDATE, and an attribute for PLOTTIME12. So I get the information on the dwg. However, I would like to be able to run all these attributes as a string. I have tried FULLFILENAME|PLOTDATE|PLOTTIME12 with spaces, commas, ( ), " ", etc. and I do not know the proper syntax to get this to work. I have also tried (getenv "FULLFILENAME") or the getvar, in the title descriptions box. I need help and have used almost 2 straight days trying to find the right combination. Does anyone have any ideas?
thanks
Gail
You can use fields (whitin a Mtext or Text).
Create a text and copy&paste following codes
- full name --> %<\AcDiesel $(getvar, dwgprefix)$(getvar, dwgname)>%
- pltodate --> %<\AcVar PlotDate \f "MMMM d, yyyy">%
- plottime --> %<\AcVar PlotDate \f "h:mm:ss tt">%
You can combine the last two in a single code --> %<\AcVar PlotDate \f "MM/dd/yyyy h:mm:ss tt">%
Various date&time formats can be used.
All codes can be used in a single text line, like this:
%<\AcDiesel $(getvar, dwgprefix)$(getvar, dwgname)>% | %<\AcVar PlotDate \f "MMMM d, yyyy">% | %<\AcVar PlotDate \f "h:mm:ss tt">%
Plot date and time will be updated only after a new plot.
