Hi All,
I meet problem with autocad OEM, I don't know how to load arx in autocad OEM,If some one know it, please tell me.I can't find the way for this problem.I'm using visual stuido 2008 sp1 for building example arx and then i will load it in autocad OEM. I use command "arx" to load it, but it not work.I have a list arx files, i want it auto load list arx files when i start autocad OEM.I can't the way for it. i'm using AutoCAD OEM 2011.
Thanks.
yes, when i command appload,ap, it not show diaglog for me select arx,and i don't know what difference object arx for autocad and autocad oem?,we need to modify object arx when we use autocad oem?
Does OEM AutoCAD even support the loading of third-party ARX/DBX files? Check with whoever sold you the OEM package.
Hi all,
I don't know config object arx for build it,using it in autocad oem, If i want to load arx in autocad oem, what i need to do?
config visual studio 2008 for build arx?? or some things. please tell me detail about it.
Only ARX applications that are built along with the OEM application itself and are bound to that OEM application can be loaded into that OEM application.
To load at startup an ARX in AutoCAD OEM, you have to add it in the page Your modules in the AutoCAD OEM Make Wizard and check Required ObjectARX.
