Hi
I have been hunting arround to find a way to read a survey file as per attached and output a polyline. It contains the start coordinate in x,y format then a list of distances and bearings in 4<120d35'34' format. I thought it would be easy, I would write some code but am flat out. For us 0d is north.
Solved by Kent1Cooper. Go to Solution.
@richie_hodgson wrote:
Hi
It is easy. tell me, do you have any other info to add like layers?
Save the information as a .scr file.
Add "Pline" as the first line.
Add "@" in front of each line (you can use find and replace function in MS Word, replace ^pwith ^p@
Then use SCRIPT command to load and run above scr file.
Then you can rotate, mirror and do whatever to make 0d as north direction.
pline
25,25
@10<45d00'00"
@20<90d00'00"
@50<120d00'45"
Then use SCRIPT command to load and run above scr file....
And then, there's that approach
Good one 3wood 🙂
Nope I can deal with layers later
I see, you can try 3woods suggestion for scripts.
Holler if you still need a lisp routine approach.
... I have been hunting arround to find a way to read a survey file as per attached and output a polyline. It contains the start coordinate in x,y format then a list of distances and bearings in 4<120d35'34' format. ...
Not very hard.... Here's a way to do it that doesn't require editing the text file, or making a different file type out of it, so you can use such files directly as received [minimally tested on only your sample file]:
(setq fil (open "C:/Your/File/Path/Survey File.txt" "r"))
(command "_.pline" (read-line fil)); first line = start point
(while (setq lin (read-line fil)) (command (strcat "@" lin))); subsequent bearings
(command ""); end Polyline
(close fil)
Hi Kent the previous post didn't apear to work, I have had a tinker to do the same thing with a coordinate file as per attached, it currently doesnt seem to work, its probably an easy fix, can you help.
... I have had a tinker to do the same thing with a coordinate file as per attached, it currently doesnt seem to work....
Try something like this [untested] -- simpler because the first line isn't a different kind of input from the remaining lines:
(command "_.pline"); start Polyline
(while (setq lin (read-line fil)) (command lin)); feed in coordinates
(close fil)
