How can i access to subentity with using (ssget "c" pt1 pt2)
The qustion is not very clear ahmet471985, are you wanting to select objects on a specific coordinates on a drawing screen or layout?
Has this something to do with your other thread "how to access to nested ojects with ssget function?" Is this new thread a re-phrased version of the other one?
İ want to ask How to using :N mode in ssget .Can be (ssget "c:N") for accessing Nested objects.
You know what, I dont really know
Never did use that selecton mode, A wise man once told me, that method produces unreliable result. so i shied away from that,
I haven't used that one, either, but certainly you don't want the c in there, but rather just (ssget ":N"). Using the returned results looks complicated -- the AutoLISP Reference directs you to call (ssnamex) with transformation matrices to get at the nested entity somehow, since what actually goes into the selection set returned by (ssget ":N") is the parent entity [e.g. the Block it's nested in].
