Valued Mentor
mdhutchinson
Message 1 of 4 (224 Views)
How can I automatically issue a 'Resume' command if the script fails?
224 Views, 3 Replies
11-15-2013 11:04 AM
How might I automate issuing 'RESUME' in a script if the script fails?
Distinguished Mentor
BlackBox_
Message 2 of 4 (210 Views)
Re: How can I automatically issue a 'Resume' command if the script fails?
11-15-2013 12:08 PM in reply to: mdhutchinson
There's obviously a reason why the Script failed, so to programmatically 'resume' could put you in an endless loop.
"Potential has a shelf life." - Margaret Atwood
Autodesk Exchange Apps ~ Autoloader ~ AutoCAD Security
Valued Mentor
mdhutchinson
Message 3 of 4 (200 Views)
11-15-2013 01:40 PM in reply to: BlackBox_
If the script has failed... then RESUME command would continue with the next line - INDEED... the next line after the line which failed. The whole point in scripts is so you can let it run - uninteripted - as well as not baby sat. This is a great place to use FileLogOn at the start of a script... so you can investigate the point of the failure.
capeesh?
dgorsman
Message 4 of 4 (189 Views)
11-15-2013 02:11 PM in reply to: mdhutchinson
Scripts have no user input or error handling, so if something fails bad things can happen.  The script could be continuing forward from a state where you expect it to work, but instead its issuing E;ALL;SAVE;CLOSE or simply firing off unknown options to one of the looping commands.
If you want more complex handling of error conditions, you will need to switch to something other than scripting.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
You are not logged in.
Ask the Community
