Hi all,
I need a little help calculation a viewport scale of 1"=30'.
I've looked around and only find nearly what I looking for. For 1"=20' I have a value of 0.004167 Paper Units = 1 Drawing Units, but what is the formula to clculate 1/30"=1'-0"?
Thank you.
Solved by Kent1Cooper. Go to Solution.
@mid-awe wrote:
.... For 1"=20' I have a value of 0.004167 Paper Units = 1 Drawing Units, but what is the formula to clculate 1/30"=1'-0"?
1/360 [just as that decimal number is 1/240 -- there are 360 inches in 30', or if you prefer, there are 360 thirtieths of an inch in a foot]. If you select a Viewport outline, in the Properties box "Custom scale" slot you can type it in just that way, as a fraction, which will be precise, unlike typing in a number to some number of rounded decimal places. It will very likely "read" there as 0" afterwards, depending on your Units display settings, but don't let that throw you -- it will operate correctly.
@mid-awe wrote:
Thank you Kent. ....
BTW- it was news to everyone that we could simply enter a fraction. Thank you for the awesome tip. 🙂
You're welcome. And you can enter a fraction, including a number plus@ a fraction with a hyphen separator, just about any place it's looking for a number or a distance -- as an Offset distance, as a coordinate in a Move or Copy displacement, even combined with other formats [e.g. @3-2/3,4.25,0], as a Text height, as a rotation angle, as a scale factor, etc., etc. A little further discussion is available here, and I'm sure elsewhere.
Here are a few registry entries for custom scale lists, not sure what version of CAD you're on though. Rename to .REG and double click to add them to the registry.
These will stay put when you reset the scale list as well. Enjoy!
