Visual LISP, AutoLISP and General Customization
*Expert Elite*
Kent1Cooper
Message 21 of 25 (162 Views)
Re: Help with exporting point locations to text file
06-11-2012 02:54 PM in reply to: Cadastrophe1911
Cadastrophe1911 wrote:
Why am i getting this error
Command: drill20
; error: bad argument type: 2D/3D point: "29.31"
Sorry about that -- the (trans) should be applied to the point before extracing coordinates, not to the extracted coordinates.  Change this:
      (trans (rtos (car x) 2 4) 0 1) "\t" ; X coordinate <--- edit precision
      (trans (rtos (cadr x) 2 4) 0 1); Y coordinate <--- edit precision
to this:
      (rtos (car (trans x 0 1)) 2 4) "\t" ; X coordinate
      (rtos (cadr (trans x 0 1)) 2 4); Y coordinate
Kent Cooper
Message 22 of 25 (158 Views)
06-11-2012 03:13 PM in reply to: Kent1Cooper
(defun C:drill20 (/ ptfile inc ptlist);
  (setq
  ptfile (open "C:/TEMP/PTFILE.TXT" "w"); <---- edit file path & name
  inc 0
  ptlist
    (mapcar
      '(lambda (x) (cdr (assoc 10 (entget x)))); Point locations
      (mapcar 'cadr (ssnamex (ssget "_X" '((0 . "POINT"))))); all Point entities in drawing
    ); mapcar & ptlist
); setq
(write-line "Units\tInch" ptfile)
(foreach x ptlist
  (write-line
    (strcat
      "WPT\t"
      (itoa (setq inc (1+ inc))) "\t"
    ); strcat
    ptfile
(princ))
  (close ptfile)
); end defun
That works.. do i have my PRINC in the right place and format???? it still gives the nil
*Expert Elite*
Kent1Cooper
Message 23 of 25 (144 Views)
06-12-2012 07:23 AM in reply to: Cadastrophe1911
    (mapcar
(princ))
  (close ptfile)
); end defun
The (princ) should be the last thing before the final closing right parenthesis.
It also occurred to me that it could be streamlined just slightly by translating each point's location from World to Current CS only once, instead of separately for each of the X & Y coordinates.  Try this:
  (setq
    inc 0
    ptlist
    (mapcar
      '(lambda (x) (trans (cdr (assoc 10 (entget x))) 0 1)); locations translated to current CS
    ); end mapcar & ptlist
  ); end setq
  (foreach x ptlist
    (write-line
      (strcat
        "WPT\t" ; WPT + tab
        (itoa (setq inc (1+ inc))) "\t" ; sequence number + tab
        (rtos (car x) 2 4) "\t" ; X coordinate + tab
        (rtos (cadr x) 2 4); Y coordinate
      ); end strcat
      ptfile
    ); end write-line
  ); end foreach
  (close ptfile)
  (princ)
); end defun
Kent Cooper
Message 24 of 25 (139 Views)
06-12-2012 08:34 AM in reply to: Kent1Cooper
Works Great...:smileyvery-happy: thanks
*Expert Elite*
Kent1Cooper
Message 25 of 25 (134 Views)
06-12-2012 09:13 AM in reply to: Cadastrophe1911
Works Great... thanks
You're welcome.  I also learned something I didn't know from this exercise:  it probably wouldn't even have occurred to me to wonder before whether the code for a Tab character in a text string in a .DWG file would translate correctly into a Tab in a .TXT file.  So I had to try it out, and now I know that it does [though whether I'll ever have further use for that information is another question...].
Kent Cooper
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
