I have modified an existing LISP Routine to find the weight per foot of a 2D Profile for Aluminum Extrusion.
I need to multiply the current result by 12.
I cannot figure out how to add this command or where to insert it.
Can anyone modify the attached LISP to acheive this result?
Any help would be greatly appreaciated.
Thank you
I have been looking for a lisp to multiply selected text and place the answer in a text feild, and came across this lisp, it has you select the text, then give it a multiplier, then the reulting text is the selcted * the multiplier.
