Visual LISP, AutoLISP and General Customization
*Expert Elite*
hmsilva
Message 11 of 11 (93 Views)
Re: Help with a Macro in MNL or Lisp
09-06-2013 01:07 PM in reply to: sbrusco
sbrusco wrote:
Henrique, you are a blessing to me.
If i may please press you for one more question? Once the code opens the file, its work is done. Can i leave the Word document open and terminate the lisp?
Thanks you so much for all your help.
Sal
You're welcome, Sal
after opening the document, you can close the shell window, even AutoCAD, and the .doc remains open.
EDIT:
Sal, if you do not like the shell window, is possible to open the. doc in another way, but you must correct the path to your WINWORD.EXE...
(defun c:doc (/ DOC FILE I II III PATH)
(defun DoDoc (/ FNAME)
  (if (findfile file)
    (command "sh" (strcat "\"" file "\""))
    (progn
      (setq fname (open file "W"))
      (close fname)
      (startapp "C:\\Program Files\\Microsoft Office\\Office???\\WINWORD.EXE" (strcat "\""file"\"" ))
    );; progn
  );; if
);; DoDoc
  (setq path (getvar 'dwgprefix))
  (cond ((and (setq i (vl-string-search "Projects" path))
	   (setq ii (vl-string-search "\\" path (1+ i)))
	   (setq iii (vl-string-search "\\" path (1+ ii)))
	   (setq doc (strcat (substr path (+ ii 2) (- (- iii ii) 1)) ".doc"))
	   (setq file (strcat (substr path 1 (1+ iii)) doc))
      );; and
	 (doDoc))
	((and (setq i (vl-string-search "\\" path))
	   (setq doc (strcat (substr path (+ i 2) (- (- ii i) 1)) ".doc"))
	   (setq file (strcat (substr path 1 (1+ ii)) doc))
      );; and
	 (DoDOc))
	);; cond
  (princ)
);; doc
 in the line
you must put the correct path to your WINWORD.EXE...
hope that helps
Henrique
You are not logged in.
Announcements
Need installation help?
Ask the Community
