Visual LISP, AutoLISP and General Customization
Help with Lisp Routine
4 REPLIES 4
mmccomb
146 Views, 4 Replies
I'm modifying a lisp routine from a former employee.
Below is the lisp code located in the acad2007doc.lsp
I'm not sure why there's multiple \\\\ slashes between file name.
This lisp is supposed to load the latest page setups from our template, everytime I open a drawing.
I'm mapped to the K:
The only thing I've changed is the file path (I've checked spelling 100 times).
(cond
((= (getvar "loginname") "TW")(command "-PSETUPIN" "K:\\\\Software\\\\Building Systems\\\\ThermalTech Drawing Template\\\\TE Standard-Mich - BS2007.dwt"))
((= (getvar "loginname") "DB")(command "-PSETUPIN" "K:\\\\Software\\\\Building Systems\\\\ThermalTech Drawing Template\\\\TE Standard-Mich - BS2007.dwt"))
((= (getvar "loginname") "CTY")(command "-PSETUPIN" "K:\\\\Software\\\\Building Systems\\\\ThermalTech Drawing Template\\\\TE Standard-Mich - BS2007.dwt"))
((= (getvar "loginname") "KRH")(command "-PSETUPIN" "K:\\\\Software\\\\Building Systems\\\\ThermalTech Drawing Template\\\\TE Standard-Mich - BS2007.dwt"))
((= (getvar "loginname") "RD")(command "-PSETUPIN" "K:\\\\Software\\\\Building Systems\\\\ThermalTech Drawing Template\\\\TE Standard-Mich - BS2007.dwt"))
((= (getvar "loginname") "MDM")(command "-PSETUPIN" "K:\\\\Software\\\\Building Systems\\\\ThermalTech Drawing Template\\\\TE Standard-Mich - BS2007.dwt"))
((= (getvar "loginname") "BW")(command "-PSETUPIN" "K:\\\\Software\\\\Building Systems\\\\ThermalTech Drawing Template\\\\TE Standard-Mich - BS2007.dwt"))
((= (getvar "loginname") "CPK")(command "-PSETUPIN" "K:\\\\Software\\\\Building Systems\\\\ThermalTech Drawing Template\\\\TE Standard-Mich - BS2007.dwt"))
(T (command "-PSETUPIN" "P:\\CAD\\TEMPLATES\\TE STANDARD.DWT"))
);end cond
4 REPLIES 4
in reply to: mmccomb
That makes 2 of us. There should only be two slashes. Four slashes will result in 2 slashes. Such as K:\\Software\\Blah blah
blah... Refer to the next to last line of your code: P:\\CAD\\TEMPLATES\\TE STANDARD.DWT
I like to use a forward slash instead. I.E. K:/Software/Blah blah blah... This way you only need one. I'm not sure if one way is
better than the other (\\ vs. /)
Give it a shot with two backslashes or one forward slash.
Matt W
"That's my only real motivation is not to be hassled, that, and the fear of losing my job. But you know, Bob, that will only make
someone work just hard enough not to get fired."
wrote in message news:5374033@discussion.autodesk.com...
(cond
);end cond
mmccomb
I've switched some things around a little.
I'm getting two errors while opening a drawing.
Errors:
; error: misplaced dot on input
; error: syntax error
Updated Code:
(cond
((= (getvar "loginname") "BW") (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
((= (getvar "loginname") "CPK") (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
((= (getvar "loginname") "CTY") (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
((= (getvar "loginname") "DB") (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
((= (getvar "loginname") "JAH") (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
((= (getvar "loginname") "JJB") (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
((= (getvar "loginname") "JPS") (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
((= (getvar "loginname") "KRH") (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
((= (getvar "loginname") "MDM") (command "-PSETUPIN" K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
((= (getvar "loginname") "RD") (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
((= (getvar "loginname") "TW") (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
(T (command "-PSETUPIN" "K:\\Software\\Building Systems\\ThermalTech Drawing Template\\TE Standard-Mich - BS2007.dwt" "*"))
);end cond
The following line is missing the " before K:\\Software...
((= (getvar "loginname") "MDM") (command "-PSETUPIN" K:\\Software\\Building Systems.....
Add the " and give it a whirl!!
Matt W
[Pardon my curiosity, but I'm wondering what this whole thing is for. It
looks to me as though it will do exactly the same (command) function, using
the same drawing template, whether the 'loginname' value is one of those
listed or not (the T line at the end covers any other possible value for
'loginname', including no value at all). If that's really the case, you
could skip the (cond) part and all the multiplicity of lines of repetitive
code, and just do the (command) function on one line and be done with it.
If it's supposed to be doing the same thing for any of those users, you
could simplify it by putting their loginnames into one list and doing a
simpler (if) function with a (member) check for the loginname, again with
the (command) function needed only once.
But in either approach, shouldn't it do something *different* if 'loginname'
isn't right, instead of doing the same thing no matter what? Otherwise
what's the point of checking 'loginname'?
Kent Cooper]
wrote...
Errors:
Updated Code:
(cond
);end cond
”Boost
